A little tip for Procharger FMIC guys...
That picture was taken when the engine was still fairly new. I leave the PCV off at the beginning to see if something with the motor is wrong. If the motor is hurting, it will start to smoke excessively out of the PCV. Just a trick.
The PCV is hooked up to the blower suction now with an aircraft air oil separator in line.
Originally Posted by BIRDONNOS
does it hurt to leave the pcv unhooked and vented to the air.
Originally Posted by 2000silverbullet
Got any pics of that? Where did you get it from, and how does it work? ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
They work well, but are kind a paint to find a place to mount. I put mine where my AC charge tank used to be.
Is your crank case capped off as well? The valve cover 90 degree angle piece.
