Vortech and cold starts
Old Nov 16, 2004 | 04:10 PM
tici's Avatar
Default Vortech and cold starts
In the owner's manual of my Vortech SQ they say to avoid start ups below 25F
"failure to comply with this may result in immediate supercharger failure"
WTF?
Our winters are colder than that, do I really have to worry?
Old Nov 16, 2004 | 04:27 PM
eviltwins's Avatar
Gear tolerances in the SQ-trims are very tight, which can cause havock at start up in very cold temps. Personally I would just disconnect the blower belt and hook the maf/TB back up to the lid for driving in the cold cold winter.
Old Nov 16, 2004 | 04:51 PM
tici's Avatar
I can also just remove the belt and load a non SC program.
Car runs like crap but who needs so much power in winter? Or is it better to duct-tape the blower and reconnect the filter to the TB?
Old Nov 17, 2004 | 04:41 PM
Got Me SOM's Avatar
if you have a block heater you should be ok, they probably say that cause at initial start up the oil is thick and at the bottom of the pan and that can cause seizure. I's run a lighter weight oil to ensure adequate lubrication.
Old Nov 18, 2004 | 09:38 AM
WSteve6's Avatar
This has me a little concerned as next year I plan on getting a Vortech. I don't drive my car in the winter but I do start it every week and let it run for about 20-25 min. I wonder if this would cause problems. I pretty much will always be running Castrol 0w-30 so I don't think it'll be too thick at startup if the oil being too thick is the reason to be concerned.
Old Nov 18, 2004 | 10:46 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Well if the car is in the garage and the garage is freezing it sounds like it can be something to watch out for. For the final word on this maybe email John Snee @ Vortech:
jsnee@vortechsuperchargers.com
Old Nov 18, 2004 | 12:20 PM
Got Me SOM's Avatar
I think you'll be fine man..
Old Nov 18, 2004 | 12:44 PM
VortechC5's Avatar
I never knew that before. That is really good info to have!
WTF?
Old Nov 18, 2004 | 01:05 PM
WSteve6's Avatar
I emailed John Snee and this is what he had to say:
"Hi Steve,
In order to achieve the low noise level of Vortech SQ superchargers, Vortech specifies precise manufacturing procedures that call for minimal internal clearance. These precise tolerances however are not conducive to temperatures below 25 degrees F. Therefore, storing the vehicle in a heated garage or employing the use of an engine block heater/aftermarket engine blanket is required when the vehicle is subjected to a “cold start-up” in ambient temperatures below 25 degrees F. Failure to comply with this may result in immediate supercharger failure.
Thanks,
John Snee"
So it might be a good idea to remove the belt, IMHO.
Old Nov 18, 2004 | 01:24 PM
LS1Tech Co-Founder
Below 25F I would just put a trickle charger on the car and wax it.
I typically only start my car when it's a bit warmer than that. I use a trickle charger on off all winter.
Old Nov 18, 2004 | 02:05 PM
WSteve6's Avatar
I should get a trickle charger. As it is probably best not to start the car in weather below freezing.
Old Nov 18, 2004 | 05:47 PM
tici's Avatar
well... mine is a daily drive 365 days a year!
I'll get the belt off: this toy is too expensive to mess with it.
Thanky you guys for your answers!
Stefano
Old Nov 18, 2004 | 10:26 PM
yano's Avatar
I believe RMCR has had 2 cars that had Vortech SC fail because they were started in cold weather, really cold around 10 above. brrrrrrr
Old Nov 19, 2004 | 01:10 AM
Inspector12's Avatar
TT-TECH Veteran
Stefano no big deal for you since you can just swap programs and run it strait through the thottlebody and disconnect the belt until the weather permits it's use etc.
Old Nov 19, 2004 | 02:23 AM
tici's Avatar
I'm lazy! What if I suck the air trough the blower and no belt?
Car won't run faster than 90 mph, but who cares in winter with ice and snow?
Jeff, it was a bad idea to show me that video! I was so happy with my numbers and now I'm thinking about... some... more... stuff to install!
Old Nov 19, 2004 | 09:34 AM
WSteve6's Avatar
Hey Guys,
I followed up a bit more with John Snee at Vortech to ask about if the other trims had to worry about cold starts. It looks like only the SQ trim has to worry. Anyway here's what he said:
All "SQ" (Super Quiet) blowers have helical gears, so you should avoid running any kit part number that ends with an "SQ" in less-than-25^ F. environments, unless you're taking the precautions mentioned below. Otherwise, just run the 4GK218-010 (satin, non-cooled), 4GK218-018 (polished, non-cooled), 4GK218-060 (satin, Aftercooled), or the 4GK218-068 (polished, Aftercooled), and you will have no worries (except the audible gear whine at idle, which some people love).
Thanks,
John Snee
Old Nov 20, 2004 | 01:44 PM
Got Me SOM's Avatar
jit might be in the owner's manual.
Old Nov 22, 2004 | 02:28 AM
tici's Avatar
It's in the guarantee papers...
Also that they wont give you any guarantee if the kit is sold outside the USA...
See where I live and imagine how I felt when I saw that
