Who all has removed EVAP?
Old Nov 23, 2004 | 02:05 PM
xssive's Avatar
Default Who all has removed EVAP?
I know this is fuel system related, but most people with extensive fuel mods are FI guys, so...
Who has removed it. What did you do with the hard line to the front. Do you have tank filling problems? How did you vent the tank?
Old Nov 23, 2004 | 02:10 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I am running a custom Speed Inc. sheetmetal gas tank that is vented from the top.
Old Nov 23, 2004 | 02:29 PM
Tiago's Avatar
I deleted it all together.
Used the hard line as my new return. left the line coming from the tank in the back just hanging there venting.
No filling or smell problems some people talk about.
Old Nov 23, 2004 | 03:54 PM
MIGHTYMOUSE's Avatar
i removed it completely from the front and it just vents from the plastic line out of the tank. no filling problems ever.
Old Nov 23, 2004 | 06:39 PM
xssive's Avatar
Ok, so from smokinHawk's picture, which lines are you guys leaving disconnected on the tank?
Also, I havent dropped the tank so I dont really know, but the evap canister in the tank... is that removeable?
Last edited by smokinHawk; Nov 24, 2004 at 05:20 AM. Reason: fixed my name, im not slowhawk :)
Old Nov 24, 2004 | 05:23 AM
smokinHawk's Avatar
Hmm that looks familiar.
OK you see the yellow zip tie attached to the black hose? that is the vent line, you can see on that pick how i pinched off the hose, i first thought when pressure built up it would press pass that, well i was wrong, i couldnt fill my gas tank cause the pump nossle though it was full do to no venting. So i cut the zip tie and used that hose just sticking out like that withough the zip tie and everything has been working fine, you cant smell gas and no leaking.
i also took off the charcoal evap canster filter so look on how i routed the other line for that. that is a black box, i maybe save a pound or two from removing it.
Old Nov 24, 2004 | 06:31 AM
WHPLASH's Avatar
Good thread. I've been having trouble putting gas in my tank also and throwing an EVAP code. Its kind of embarassing trying to fill up your tank and having gas go all over the place and you've only put in .12 cents worth. LOL
Thanks
Old Apr 18, 2005 | 06:48 PM
Irocss85's Avatar
for some reason, I cant see the pic. can someone copy it and send it to me so I can look at whiplash's car? thanks in advance.
chris
Old Apr 18, 2005 | 06:55 PM
HellRaiser's Avatar
I think it's this one.
Thats smokinHawk's
Old Apr 19, 2005 | 06:22 AM
smokinHawk's Avatar
ya i rearranged my site since then.
but you can see the black tube that has a yellow zip tie. dont kink that hose it needs to vent.
here is the link to my fuel set up
http://www.cofba.org/users/smokinhawk/fuel.htm
