Rear mount oiling...advice requested
Old Nov 25, 2004 | 07:59 PM
Jammer's Avatar
Default Rear mount oiling...advice requested
Running a pair of rear mounted turbos obviously requires special attention with regards to oiling. My current thought process is to have a line rin from above my filter, to a "t" in the rear, and to feed each turbo...then run a -6 drain from each turbo to a "y" block and to a -8. From there, mount a Welden 9200, continue -8 to a check valve and into the upper portion of the oil pan. Ant thoughts on if this will work or be sufficient?
Is there some type of low oil/pressure buzzer or indicitator I can add? Is one turbo likely to get more oil than the other? Will I suck too much oil, jeopardizing anything else?
Any input appreciated.
J-
Old Nov 25, 2004 | 09:59 PM
trtturbo's Avatar
curious as to the thought process. What turbos, what car, what size turbos? Share a little more if you would. If its as f-body, where in the rear will you put them?
Old Nov 25, 2004 | 10:35 PM
Jammer's Avatar
99 30th ta vert.
Sold old traditional front mount twins to try new adventure. These are 76mm turbines and compressors(To4E) on a forged 408 with all necessary chassis, fuel and driveline upgrades. Basically left an expected 1000 rw system for this 700+ system (goals).
I learn as I go, and as usual, Im going somewhere new again so I like the input the forums usually provide. I considered Incon location but the turbos are too big so were back by the axel now. I really just need to better comprehend the oiling system so to give it its best chaance of being successful. Basically, I could use a schematic. I contacted STS about being part of this (Brandon??) and though they sounded interested, they didnt return calls or email requests which is too bad. I spoke with Rick in Oct '03 and he said twins were just not necessary, so wanting twins, I went another direction at the time...now Im back to do this for ***** and giggles. Something to keep busy with until I can no longer hold back the desire for a C6 TT.
Long an d short of it, I need someone that has done it to better guide me or add input since there is no information as good as from those who have bumped into brick walls or pit falls. You know who you are...Sly, Flipper...Etc. Lets hear it! Where and what type of check valve..where should I mount it...where and what low pressure indicator...what should the design look mlike and why. Just want opinions!!!
Old Nov 25, 2004 | 11:01 PM
Redline-Motorsports's Avatar
J,
I still think that setup will require some kind of return pump to get the oil back. Not much gravity to get it back to the pan.
You got the right idea getting it there though.
HT
Old Nov 25, 2004 | 11:06 PM
Jammer's Avatar
HT, I am ordering the Welden 9200 A Ajustable return oil pump.... Im next in line when your plumbing is done BTW! Talk to ya soon.
Old Nov 26, 2004 | 07:16 AM
PurEvl's Avatar
700 hp should be easy
Old Nov 26, 2004 | 07:50 AM
Slowhawk's Avatar
LS1Tech Sponsor
All sounds good but I would ditch the check valve and dump the oil into the valve cover.-Back pass side fitting.
Old Nov 26, 2004 | 03:03 PM
Jammer's Avatar
up up up
Old Nov 26, 2004 | 06:42 PM
Billy the Great's Avatar
why not run a dedicaated oiling system with a tank in the back well or under the car?
i have no idea what that would involve but it sounds less complicated
Old Nov 26, 2004 | 06:44 PM
slyws6's Avatar
Ok here's what I did. Pretty similar to your setup, however to monitor oil pressure I ran a tri gauge pod with Boost, AF Ratio and, Oil Pressure. The oil pressure gauge came with it's own sensor so I mounted it at the back of the car and ran the wiring back there. Only problem with this, is that you have to monitor the oil pressure yourself. I used a weldon return pump as well. As for the check valves, I just went to the auto store and searched through their array of PCV valves for one with a 3/8's in/out and put it on the pressure line. The oil pressure should equalize between the two turbo's as long as there are no restrictions to each of them. Other than that the rest sounds good to me.
-Sly
Old Nov 26, 2004 | 06:46 PM
slyws6's Avatar
That was my original plan when I built mine. The only problem with that is that since the turbo's sit so low and are gravity return you would need 2 oil pumps for both pressure and return. That's not too big of a deal if you are willing to spend another $200 or so for the additional pump, and another $100 or so for a reservoire.
-Sly
