please post if interested in sdce gp
SDCE 8 rib spring tensioner 3-5 $625.00
SDCE 8 rib spring tensioner 5 or more $595.00
Thanks SDCE and Wendy for offering this GP.
Thanks Nick and good luck getting your system together. If you need any help or advice, please ask.
Nope SDCE uses your bracket and modifies it. Yep it will work with a true tech steel bracket. SDCE used my automotion steel bracket and modified just fine.
as for the F1R, if it works with the ATI bracket -SURE!
I use it and HIGHLY recommend it.
Wendy, I'll call you guys on Monday. I've been trapped in North Canada for the past week.
Works flawless, and I still don't have it 100% lined up.......
Its probably 85% correct and I still make a consistent 15psi, just throw a belt from time to time.......I'm still running the standard bent aluminum bracket though, I need to get a steel one eventually
As far as some of the other questions, yes, we accept visa, mc, discover, amex...
We modify your bracket. Either the ATI or any aftermarket steel bracket (thanks J!) We've yet to see any clearance problems with the steel brackets. If you need a bracket, we can sell you an ATI aluminum bracket.
As far as the F1R, Scott THINKS it will physically fit in the bracket...we haven't had one here just yet to work with. He thinks you'll have to worry about the inlet/outlet sizes and the blower may be longer making it closer to the radiator.
I run an F1, and I have NO room to run a filter of any kind at all.....the only way we are thinking about getting one in there is to stand the radiator up......I'm not too worried about it for now considering I don't drive my car anywhere "dangerous" for that situation
They put a screen over the inlet, but that didn't cut it, took away too many ponies
