Which wastegates
Old Dec 10, 2004 | 05:29 PM
Boostaholic's Avatar
Arrow Which wastegates
So I have not ordered wastegates yet, but I have called a few places and got different stories about which wastgates I should get
right now its between the HKS "Race" wastegate, approx $900 each, or the TiAL 46MM wastegate, about $400 each.
Can anyone tell me cons of the TiAL wastegate? Or give me a good reason to spend a extra $1000 on wastegates and go with HKS RACE gates?
Old Dec 10, 2004 | 05:39 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
The HKS is a nice unit but overpriced. The Tial is a nice unit as well, but race fuel is not allowed with it unless you get the upgraded valve. For the money the best unit by far is a Turbosmart progate 48mm. Flows as much as a HKS race wastegate, costs around the same as a Tial version, and comes already with a 253MA valve which will handle race fuel and anything else you can throw at it.
Jose
Old Dec 10, 2004 | 06:10 PM
NA$TY-TA's Avatar
Jose
So i take it by what your saying Jose is that i cant use a Tial wastegate and C-16????? If not then i will be getting one thst i can use with reg. pump 93 octane and C-16......
Kyle
Old Dec 11, 2004 | 09:16 AM
KAOS's Avatar
not to hijack a thread but can you run race fuel with a hks standard wg?
Old Dec 11, 2004 | 10:17 AM
smokinHawk's Avatar
I was going to say use the prosmart also, check out Jose's site, he has them at a good price, havent found a cheaper place yet
Old Dec 11, 2004 | 10:39 AM
eviltwins's Avatar
We run 44mm tial gates on my wife's car, put race gas through them all the time. They're reasonably priced at around 700 for the pair, and hold boost very well. A pair of HKS GT gates is hugely overkill. Pro 5.0 cars making 2000+ horsepower run a single HKS GT gate.
Old Dec 11, 2004 | 10:49 AM
LS1TECH Sponsor
The Tial's you can run race fuel through, but you need to check them regularly. I have had a few customers that have had them stick. Also the HKS units as well. The test supra that we used for testing turbos went down with a rod through the block thanks to a stuck HKS wastegate....ouch. We sell all the units and brands, so I'm not being biased, but a stuck wastegate can be an expensive mistake.
Jose
Old Dec 12, 2004 | 03:53 PM
Louis's Avatar
The Tials already come with the upgraded Inconel valve in the 44s/46 mil valves. DSM guys run c16 all the time with no complaints.
Old Dec 12, 2004 | 07:47 PM
sr71's Avatar
ok. does anyone care to explain why you can't run race gas with some gates?
Old Dec 12, 2004 | 09:56 PM
Louis's Avatar
The Tial 35mm wastegate comes with a valve that is not meant for leaded gas and thus gets corroded and swells ( sticks closed/open). Tial has an option on the 35mm so you can get a hard chromed stem (comes std. on the 40[discontinued], 44 & 46mm) that is good for the leaded stuff.
I am assuming the same is true for the HKS stuff.
Old Dec 13, 2004 | 12:46 PM
sr71's Avatar
thanks for the info...I learn something new everyday.
