STS turbo system Part sub fram connector?
Old Dec 11, 2004 | 01:42 AM
Lawnboy's Avatar
Restricted User
Default STS turbo system Part sub fram connector?
I hear that the discharged pipe that runs from the turbo to the front of the car is very strong and also acts as a drivers side subfram connector.Is this true, is the pipe realy that strong, if so what sub fram conector (Brand) would work well on the passenger side??? I would like to install a subFram connector on the other side so that my car dont flex. Would like one that is no too heavy and bolts in just to the front and read of the car not in the middle. Thank you for your help.
Old Dec 11, 2004 | 09:56 AM
PurEvl's Avatar
yes its strong, I run a wolfe tubular on the other side
Old Dec 11, 2004 | 10:58 AM
trtturbo's Avatar
There are quite a few that will work, but you may have to find someone that wrecked their car on the drivers side to get one. That would be better than buying both and just using one.
Old Dec 11, 2004 | 03:08 PM
Arkangel77's Avatar
I hade to CUT my BMR out to install the STS part. It seemed to be toughf enoughf. Lata, Ark
Old Dec 13, 2004 | 07:15 AM
No Juice's Avatar
Is the pipe actually welded to the car subframes? Otherwise I don't see how it can possibly work as a SFC. What kind of piping is it? Either way I don't see a thin wall piece of tubing preventing the car from flexing.
Old Dec 13, 2004 | 09:20 AM
Arkangel77's Avatar
Its a Bolt on Part BUT it can Be welded! I welded Mine In! Its Just like most other Sub Frames!
Old Dec 13, 2004 | 04:19 PM
No Juice's Avatar
I didn't know shops use roll cage tubing for exhaust
Old Dec 13, 2004 | 04:38 PM
Arkangel77's Avatar
if that was in reply to me I was saying it mounts like most other SFC.
