took the car for a drive today...SDCE people in here please
Old 12-15-2004, 07:32 PM
BIGBOS's Avatar
Default took the car for a drive today...SDCE people in here please
I took my car out after it sitting for about a month....fired up right away, but still had the misfire......so I take it to my buddies shop and we swap the plugs and start it up.....it was still misfiring........we drove it just to make sure....so we bring it back, look over things, and notice that the belt on the tensioner pulley was skipped over a few ribs rubbing up agaisn't one of the drive pulleys....
I shut the car off, took a wrench to the bolt that holds that tensioner in place, pushed it back to get some belt slack and put it back to normal position, started the car up and the misfire was gone........my tension is set at 15, yellow to yellow.........I'm just wondering if any of you have had that happen before? Shouldn't there be enough tension on there to prevent the belt from wanting to jump at WOT...????
I took it for a blast or 10 after everything was set and man did it feel good......15psi consistently, no dust, etc.......rush hour traffic was in awe
I plan on taking the car out on a 2-3 week basis, instead of storing it........I'm too lazy And I like the feeling of all this horsepower in the middle of winter
Old 12-15-2004, 10:08 PM
NA$TY-TA's Avatar
Thats wierd.......
Old 12-16-2004, 12:35 AM
frcefed98's Avatar
Very weird, my is doing just fine and its on the road everyday with daily boost abuse.
No belt jumping here..
J
Old 12-16-2004, 02:03 AM
Billy the Great's Avatar
bos i need a ride in this thing asap.......then ill tell ya why i think the belt is jumping
Old 12-16-2004, 07:39 AM
BIGBOS's Avatar
You'll get a ride when you get back home
Old 12-16-2004, 08:28 AM
SDCE's Avatar
Brian,
Make sure it's straight...that usually only happens when it's not on straight.
Was it fine every single time you hammered it after that?
Old 12-16-2004, 10:11 AM
BIGBOS's Avatar
Yea, I whacked it 4 or 5 times after that and it was fine.......
Its never happened before with it, thats why I was asking
Old 12-16-2004, 10:18 AM
NoGo's Avatar
Mine has been going strong. I took the car out yesterday for some 17 psi fun in this winter cold.
Old 12-16-2004, 10:31 AM
BIGBOS's Avatar
Yea, I'm already tempted to put more boost through this thing.....
I could step down to a 3.2" pulley, that would put me around 17psi.......get a 51.5" belt to go on it.......
But then.......I'll most likely need more injector.........and might as well do a BS3 while I'm doing that, and along with the converter I'm currently saving up for......
List NEVER ends.....
**** I don't even have a rollcage yet
Old 12-16-2004, 10:59 AM
NoGo's Avatar
Just go 72 lbers they work okay with the stock computer. There is a little trickery, but they do work.
A 3.2 with an F1 5:1 step up. Holy sheet you must be spinning the crap out of that thing. A good testiment to the SDCE kit.
Old 12-16-2004, 11:34 AM
1dirtyZ's Avatar
cages are for sissies
are you sure the missfire wasn't caused by a bad coil wire ( the ones that plug into the side of the coils)? i had the same problem ( less the belt skippage) and couldn't trace the missfire till i stumbled accross a cut wire on one of the coils.
if you are worried about the belt tension, take it up a bit just to be safe.
and you think your car is a rush now, wait till you race a bike an beat them!
Old 12-16-2004, 12:55 PM
BIGBOS's Avatar
We checked all the wires, they are good.....
Nogo, I don't have the 3.2" on there yet......I'm running the 3.4", but if I want more boost, thats my next option
That will put the blower right around 70,000 max impeller speed.......its floating at 68,500 right now with where I shift
Old 12-16-2004, 01:00 PM
Adkoonerstrator
XLR8NSS's Avatar
Maybe a small rock or something off the road got caught up under the belt and made it skip over?
Old 01-02-2005, 05:14 PM
BIGBOS's Avatar
I'm still having this problem w/the belt "walking" on the spring tensioner......
Under WOT it will move over 1 or more ribs depending on how hard I whack it, now when the car is idling, this tensioner has some considerable wobble to it, this is normal because its a spring tensioner........I wonder what I should do to take out the slack or compensate for it......
any ideas people.......
I'm 100% sure this is why I can't keep a belt on past 3rd......
Old 01-02-2005, 06:47 PM
frcefed98's Avatar
Bos, mine doesn't wobble? You can see the spring tensioner riding the belt up and down, but when I whack the throttle you can see the spring tensioner push down on the belt like its suppose to do....Are you still using your custom standoffs or Did you go back to the stock ATI ones and the SDCE washer/spacers? I'd use the SDCE/ATI stuff and go from there.
Still sounds like you are misaligned.
J
Old 01-02-2005, 06:50 PM
7 Second Club
BlwnTA's Avatar
Bos, I never had this problem and I don't think Jeremy has either. It has to be either alignment or a bad component (Tensioner). Are you sure you tightened the plastic idler (bottomed out) before you loaded the belt on the tensioner. I did this backwards one time and caused a few problems but I caught it pretty quick and fixed it. Good luck let us know!
Mark
PS: Cool J and I must have been posting at the same time!
Old 01-02-2005, 08:50 PM
MstgKillr's Avatar
My SDCE is almost perfect. The only problem I have is the 4.0 pulley is slightly too big and ground off part of the outer rib. That can easily be fixed with a smaller pulley . More boost . Hopefully my stock bottom end don't
Old 01-02-2005, 10:36 PM
MelloYellow's Avatar
Gates Laser Belt alignment tool.
Old 01-03-2005, 03:26 AM
BIGBOS's Avatar
Well my belt still gets grooves in it from the middle 90mm idler, but the grooves are right in the middle of the belt now, so I know the assembly is aligned.....not sure about how the belt acts at WOT though....
Old 01-03-2005, 10:39 AM
SDCE's Avatar
Don't go by where the grooves are...if it was aligned, it wouldn't ride up...what shims are you using? Can you call us so we can help? I've left a message on your cell...
Quick Reply: took the car for a drive today...SDCE people in here please
