Compressor map for Super T-76 turbonetics
When looking at the compressor maps I found the T-76 would be ok for my app, when running relitivly low boost with low RPM ( to 6200 less then 16PSI). Allthough when I figure in how much air my heads and cam 6.0l will move at 6200-6600 and above 16 psi I start to fall out of range to were it will blow a lot of hot air. I would like to see what the Supers compressor map is and see if there claim to fame of higher boost looks good on paper too.
I just do not want to spend 1500 plus on a T-76 if its gonna run out of breath above 800fwhp.
Anyone have personal experience with the Super T-76 yet?
Thanks, BTW should be fast reg. cab S-10 huh.
TJ
sometimes its hard to find the right compressor maps.
i think a standard T76 is good for 750rwhp, and the larger trim about 780rwhp, about.
Jose
