How much is 1psi equal to in terms of power?
how much boost(psi) would it take to make close to 700 rwhp, and is it possible to keep it as a daily driver(meaing i can drive it whenever on pump gas). i want to make as much power on 91 oct(its the only stuff we have here) and im not sure what i should expect when its being put together.
the turbo will be a gt55 turbo.
A Motor is very responsive to say 4 to 5 psi of boost. A Gain of 125RWHP for a mere 4psi is not unheard of. But a Gain of 250RWHP on a 8psi blown motor, is much harder to achieve. Efficiency comes into a major role, as some kits are more efficient than others. Cam, Heads, Exhaust all play a role. Good example. My car put down 524RWHP with a Bone stock motor, 7psi of boost 3.73 12bolt.. Before the blower I dynoed 328RWHP on the same setup minus the blower. That's a gain of 28RWHP per 1 psi of Boost. Later I dynoed gain with 11psi of boost with a lower compression motor, (which lost efficiency) but should have gained it back with my cam, even though it's a 112LSA, and my stage 1 heads. All other factors stayed the same. My now 11psi motor had 621RWHP. That’s now 26.6 RWHP per 1 psi of boost. So using my car as an example, my RWHP per 1 psi of boost has gone down , even though I have better heads, and a decent cam for the blower.
I'm sure others will chime in.
Clint
Clint
either way, i think we will both agree that there are way too many variables to accurately say 1 psi = XX amount of hp/tq.
The bigger the compressor wheel...the longer it will take to spool...the 101mm would flow alot more air, but the RPM range also moved up alot. When choosing a turbo, you have to look at the efficiency range, most big turbo's are not efficient unless they are making 15+ psi of boost. The best al around turbo for single turbo set-ups seems to be the T76.
Hugger....your motor lost hp per psi, but is now alot safer, since the compression dropped.
When i have free time on my hand i will do a new list and include the FI kits results in.
As for 76mm being the best turbo.... Id say that depends on your goals, CI of your motor, etc etc. Everybody has different expectations
Rick
fully built 408 motor by FMS
stage 3 hand ported afr heads by meaux
prob somewhere around a 232/232 cam, im thinking
12 bolt with no higher then 3 73's, prob just 3 42's though
gt55 turbo, by garrett(i havent seen any specs released on it yet though)
my goal is to make as much power on 91 oct. as possible, that is my real question.
what would be your guesses i can make as far as boost and power goes?
Let's go with the ultimate dyno queen combo:
M6
stock rearend
open exhaust
good fmic (i question whether an obx is big enuff)
I will say 12 to 15psi for you to hit 700rwhp.
Variables that affect the amount of boost needed:
-engine compression
-turbo size
-down pipe/exhaust housing
A lower compression setup like 8:1 will need more boost to hit the same number as say a 9:1 setup, but your bigger concern should be about detonating on 91 pump gas. I would not get greedy with compression.
My combo is the worst dyno combo you can imagine as a comparo:
YSi supercharger
T400 trans, 4500 non lock up yank converter
9", 28" slicks
dual exhaust, 3", dual magnaflows dumped
Griffin FMIC (good thing)
I've done 746rwhp w/17 psi, 13:1 AF, 22 degrees of timing, 110Leaded
I've done 738rwhp w/19 psi, 11:1 AF, 23 degrees of timing, 110Leaded
(but have picked up 50rwhp under the curve and it's not as peaky, and it peaked at 6200 vs 6800 like last time)
My motor has recently seen 21psi but my combo was dropping off well before 6500 rpms.
I think any 9:1, FMIC combo can hit 650rwhp on pump gas 93. I think that 700rwhp is possible especially if it's a really peaky combo. But 9:1 won't leave you much room for safety. Running the car on the dyno for 3 seconds is not the same as running the car WOT for a few minutes racing a dude in a Viper. Think about my last comment and explain to me what the different is.
