703 RWHP 4x4 6.0L
Old Dec 20, 2004 | 11:48 AM
Speed Engineering's Avatar
Sponsor
Default 703 RWHP 4x4 6.0L
Just got our F1 project truck done and dynoed. We through it on the dyno with 8lb. of boost and we happy to see that it dynoed 703 RWHP. Still having a problem lifting the heads though. Any time we go above 8lb. of boost we have problems lifting the heads. We need to put bigger studs in the heads down the road. The setup includes:
-6.0L block
-Custom Diamond Pistons
-Lunati Rods
-Stock Crank
-LQ9 Heads with bigger valves
-AZ Longtubes
-Blower cam
-& we keyed the crankshaft
You guys can check it out if you like. (Link)
Sean
Old Dec 20, 2004 | 11:58 AM
LSs1Power's Avatar
Lifting heads and 703rwhp with 8psi only What is the cam specs? Whats the C/R? How much timing are u guys pushing? Is that done on pump gas or race gas? 8psi and 703rwhp is awsome.
Old Dec 20, 2004 | 01:36 PM
Sponsor
Comp 220/224 .564/.567 115. 8.1 Compression. 15* of timming with a half mix of 104 and 91. We were having a hard time keeping the tires on the dyno. They kept spinning every time it went into boost.
Sean
Old Dec 20, 2004 | 03:28 PM
LSs1Power's Avatar
So u gained around 350rwhp with only 8psi and 15 degree of timing only. Thats a 42rwhp per psi. What kind of blower are u running? That is one efficient setup u got there.
Old Dec 20, 2004 | 04:17 PM
BIGBOS's Avatar
Seems REALLY efficient, almost similar to wilkinsons F1 w/10lbs, but that was with a C5R motor......
Whats your intercooler setup consist of?
Old Dec 20, 2004 | 04:52 PM
Sponsor
It is an F1 Procharger. We used a 3 core single large intercooler. We were very supprised with the performance gain. The first charger we had on it was the Radix and when we put the F1 on it it felt like thowing a 150 on top of the old setup. It went from spinning the tires for about 10 feet out of the hole to spining them at 40MPH, around the same distance. I couldnt believe the gain we got out of it.
Old Dec 20, 2004 | 06:35 PM
blownZ's Avatar
What blower bracket are you using with this F1?
Old Dec 20, 2004 | 06:47 PM
Sponsor
Stock with Thunders belt tensioner.
Old Dec 20, 2004 | 06:54 PM
hellbents10's Avatar
LS1Tech Sponsor
Is your dyno brokin? Or did you put the wrong pully?
Old Dec 20, 2004 | 11:28 PM
BIGBOS's Avatar
What does thunder do to modify the bracket?
Old Dec 20, 2004 | 11:59 PM
Sponsor
They make it a self tensioner. So you can put as much pressure on the belt as you want.
Old Dec 21, 2004 | 10:29 AM
BIGBOS's Avatar
It gives it enough belt wrap w/no slip?
