Stock Heads for FI
Old Dec 21, 2004 | 12:09 PM
Ed Blown Vert's Avatar
Default Stock Heads for FI
How much do you guys think I will lose by going back to stock heads? Over my 5.3's?
Old Dec 21, 2004 | 01:07 PM
BIGBOS's Avatar
Well, you might pick up 1 or 2psi maybe.....its a toss up.....your going back to stock compression down from 11:1 though right?
Old Dec 21, 2004 | 01:15 PM
Yep, from 11:1 to to stock.
I just don't know if I want to spend more money on 6.0L heads.
I know lowering the CR will help. But how much can I lose from not having ported heads? And larger valves?
Old Dec 21, 2004 | 07:04 PM
Caveman's Avatar
10 & 11 Second Club
Did you get your $$s back from Jay. I remember your posts on the ASSolute thread, where you said that you wish you had paid by credit card. That guy is a jack ***!!!
Old Dec 21, 2004 | 09:30 PM
Nope, never got my money back. I have people looking for him. And a LEO helping out.
Old Jan 10, 2005 | 01:39 AM
Anyone?
Old Jan 10, 2005 | 03:18 PM
z98's Avatar
z98
You probably won't lose much.
Someone was running around 800 RW with stock heads and stock cam because they didn't pick anything up with ported heads and a turbo cam.
You might go up a few PSI though.
Old Jan 10, 2005 | 04:05 PM
Doesn't sound like I should waste another couple grand on new heads. Just go back to stock.
Old Jan 10, 2005 | 05:28 PM
NoGo's Avatar
Why don't you just have the combustion chambers of the 5.3's modified?
Old Jan 10, 2005 | 05:42 PM
I already have those heads sold.
Old Jan 10, 2005 | 05:53 PM
Country Boy's Avatar
Senior Member
Whats the chamber size on the stock 6.0s? How about Valve sizes?
Old Jan 10, 2005 | 06:05 PM
I would be going back to stock LS1 heads.
Old Jan 10, 2005 | 06:13 PM
NA$TY-TA's Avatar
71.03cc CHAMBERS and i believe 2.0 and 1.56 valves.....
Kyle
Old Jan 10, 2005 | 11:40 PM
Time2Kill's Avatar
MASS seller approved
http://www.smokemup.com/tech/ls1.php
Old Jan 11, 2005 | 12:21 AM
Arkangel77's Avatar
you can Lower compresion by Going with thicker MLS COmetic Gaskets. It might help ya a Little?
Old Jan 11, 2005 | 10:11 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If you go stock, why not get a set of 6.0 heads for the 70cc chambers, do a cleanup hone on them, and maybe a valve job. Not a bad idea to go with bigger valves on the exhaust side.
Old Jan 11, 2005 | 10:19 AM
LS1Tech Co-Founder
Oh I wanted to add that 6.0 heads I believe have smaller intake and exhaust valves than stock LS1 heads.
Old Jan 11, 2005 | 10:22 AM
Senior Member
By Tims link above, the LS1, LS6 and 6.0s all have the same valve sizes. The 5.3s have the smaller valves.
I may do the same. Sell me stage 2 5.3s and get a set of stock 6.0s with a valvejob and maybe bigger valves.
Old Jan 11, 2005 | 10:46 AM
RyanJ's Avatar
SSU Moderator
what you lose in cfm you can pic up in power from the added timing and less detonation with the lower cr. boost will obviously go up because of the lack of resistance in the motor, but you shouldnt so much get a power increase from that boost.
If you are forcing the air in it shouldn't matter. Don't get thick gaskets, keep your quench tight. put in some head studs and cc the chambers to get them the same.
Old Jan 11, 2005 | 05:00 PM
Sounds like a viable option that shouldn't cost too much.
But I also thought that the 6.0L has smaller valves. :dunno:
