STS turbo pics
Old Dec 21, 2004 | 05:02 PM
seabirdak's Avatar
Default STS turbo pics
Does anyone have some pics of a STS turbo installed, if so could you please post them?
Old Dec 21, 2004 | 05:13 PM
Z06PSI's Avatar
Look on the STS site....to your right...
Old Dec 21, 2004 | 07:07 PM
natesiy's Avatar
Old Dec 21, 2004 | 07:45 PM
PurEvl's Avatar
Old Dec 21, 2004 | 08:02 PM
cablebandit's Avatar
that will never work....hangs too low...prolly scrub if you do a wheelie where you drag the bumper. The housing is gonna crack when it gets rain on it from you doing 20 psi in the rain/snow Install looks nice. I can't wait until people with the kit get some seat time at the track with. Oughta put out some good numbers!!!!
Old Dec 21, 2004 | 10:31 PM
VaNDaL*SS*'s Avatar
ive read with those STS kits that you dont need i/c cuz the pipe from the turbo to the intake is so long that it cools down from the ambient air around it?
Old Dec 21, 2004 | 10:49 PM
trtturbo's Avatar
The one pictured is running 14psi I think.With that psi, he needs a FMIC. Pretty much anything over 5psi with the sts you need to cool the charge air to be safe.
Old Dec 21, 2004 | 11:53 PM
Arkangel77's Avatar
trttubo - That is with a stock compression ratio motor, Right?
Old Dec 22, 2004 | 12:18 AM
VaNDaL*SS*'s Avatar
if i get the STS turbo, will i need to do anything to my bottom end to run 7-9#? I know with the ATI P-1SC i can do that and still be safe with the 10.5:1 CR. If i can then i think i definatly want to go with the STS
Old Dec 22, 2004 | 12:38 AM
Deamon2002's Avatar
Originally Posted by natesiy
What's up I can't get the links to work. I really wanna see, lemme see, lemme see, lemme seee!!!!!
Old Dec 22, 2004 | 03:03 AM
studentdriver's Avatar
My install isn't quite done yet, but here are some pictures:
http://www.cardomain.com/memberpage/745173
Old Dec 22, 2004 | 08:04 AM
Armageddon's Avatar
...with cheese.
PUREVL whats up with that longer silicone coming off your tbody? What modifications did you have to make to your kit to work with 14psi? My intake pipe came pretty close to my powersteering pulley. Was that your fix for that?
Old Dec 22, 2004 | 08:13 AM
PurEvl's Avatar
lots of custom piping done by slowhawk, we moved the maf location as well. Mines the first one we tried it on and boy oh boy it made a difference in low end throttle response. To run 14psi I turn the **** No we obviously got the gt70 and fmic to push it to that level. Kept the timing very very low as well. My 10 psi numbers were at 14 degrees I believe. Don chime in here and explain the install cause i was sleeping in his garage when he did it
Old Dec 22, 2004 | 02:30 PM
Armageddon's Avatar
...with cheese.
Yea, i don't like how low the maf pipe sits right now. I'm sure if the maf was relocated it would help the throttle response too.
Old Dec 22, 2004 | 11:46 PM
VaNDaL*SS*'s Avatar
can any1 answer my question a few posts back?
Old Dec 23, 2004 | 07:22 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I ran 7.5# on my LQ9 (10.1:1) with no cooling. I ran up to 12 psi with meth. You definately have to tune for this though, and definitely need more fuel.
Old Dec 23, 2004 | 07:35 AM
PurEvl's Avatar
you can handle about 500 rwhp on stock bottom end, anything over 5 psi will require a fmic or meth
Old Dec 23, 2004 | 10:54 AM
SSnakekiller's Avatar
We have some pictures and videos on our web site.
Old Dec 23, 2004 | 11:05 AM
Slowhawk's Avatar
LS1Tech Sponsor
I highly recommend an intercooler for all the STS kit's.Methenol is just a band aid.On a stock motor I recommend 5-8lbs,intercooler,42lb injectors and a fuel pump upgrade.That will put you around 480- 500hp/450-500tq on pump gas.The STS will outpower a Procharger in the midrange.
Old Dec 23, 2004 | 11:10 AM
VaNDaL*SS*'s Avatar
cool thats what i wanted to hear. i figured that i would need the i/c the fuel pump and bigger injectors.. what if i did the meth injection with the fmic? could i run more boost on my stock bottom end? The goal for my car is to be a consistant 11's runner that is a daily driver, so im just trying to do my research on how to make power with out having to serious stuff like swapping pistions and whatnot
