72cc or 68cc with Vortech 9#?
Well... If the heads are comming off the stockers are not likely to go back on.
I started researching good "blower" heads and have a couple of questions. Keep in mind that this is my Daily Driver, I am not trying to obtain 1000hp here, just a strong 470-500 or so to keep me happy in my daily commute. I want to keep things as simple and reliable as possible.
Everyone seems to recommend 6.0L heads to drop the compression to 9.1 or so for the blower so I can run more boost without detonation. But what if I don't really plan on increasing the boost? How would the car run? Wouldn't I loose a bunch of low end grunt because of the lowered compression? Could this turn into a computer tuning nightmare? I would assume the Vortech tunning would absolutely useless at this point right?
What about Patriot's LS6 Style Stage III heads with 68cc chambers? This should lower to about 9.8 so it's not as dramatic of a compression loss as the 72cc 6.0L's, but still about a .5 drop. Wouldn't this still allow me to keep some power from the motor and keep the low end torque and grunt? Wouldn't this be a little easier to handle tunning for as it is not much different from normal stock tables?
Questions... Questions.... Questions.
What are your thoughts?
. Are you running the stock pulley or something smaller for more boost? Last question... What are the specs on your heads and who did the work? Thanks Inspector!
Inspector12, when you had an 8:1 car what was it and how did it drive?
I am 8:1 and make like 700rwhp at 5500 rpms, you think my car might be laggy at 4500 where my converter flashes?
I'm sure an 8:1 4 cylinder is quite laggy.
Thanks Inspector!
Though I really never did mention trying to stay smog compliant, it really is a concern for me, just forgot to mention it. It looks like you really understand what I looking for. That car you saw at MTI is about what I would be shooting for, something fairly easy and conservative on my 70k+ mile stock bottom end. That MTI car is still putting down about 50hp more than I would have even hoped for so that's great.
I am not trying to be the absolute fastest car around, my car is a daily driver and the way it's set up it is way too heavy to be a serious race car... But I do like having some real power under there, the average 370-400hp range has just gotten real boring for me
It looks like I will be shooting for the lower compression 6.0l's then. I was trying to initially avoid diving into smaller pulleys and custom tunning, but I also want to do it right the first time... That's the most important issue here. If lowering the compression puts down those types of numbers while still putting only 7#'s of strain on my middle-aged stock bottom... Great!
I was really worried that dropping CR this far would really kill my off the line stop-light torque, and might bring back my clutch chatter blues
. But hopefully from the looks of things I should be okay. Thanks all!
