STS turbo question
Old Dec 24, 2004 | 07:02 PM
hotrod04's Avatar
Default STS turbo question
Just started my truck up with the sts turbo and somthing is screwy. When you bring up the rpm's up around 3500 and up the rubber elbow at the intake collapses then as the rpm's come down it opens back up. What in the hell is going on? Please help. Thanks
Old Dec 24, 2004 | 07:55 PM
Slowhawk's Avatar
LS1Tech Sponsor
That is normal.Just sitting there it will collapse the outer side.When driving it won't because boost pressure is going in.The elbow is made not to expand but give's a bit on vacuum.
Old Dec 24, 2004 | 08:25 PM
hotrod04's Avatar
Thanks slowhawk, I was a little nervous when I saw it collapse, also after i run it up to about 4500 rpm and then let off of the pedal I here a couple of real squalls? is this noise from the waste gate?
Old Dec 25, 2004 | 03:52 AM
99z20ate's Avatar
That's probably the blow off valve, when u build boost and let off the gas, the air pressure has to have somewhere to go so it shoots out the bov, do u have the one that came with the kit?
Old Dec 25, 2004 | 10:55 AM
Slowhawk's Avatar
LS1Tech Sponsor
And you hear a noise when the turbo stalls.
Old Dec 25, 2004 | 11:07 AM
hotrod04's Avatar
Yes I have the one that came with the kit, do I need to change to a differant one?
Old Dec 25, 2004 | 05:17 PM
slow's Avatar
so basically this is proof that the sts kit is a restriction for normal driving?
Ryan
Old Dec 25, 2004 | 05:25 PM
PurEvl's Avatar
Ryan
wtf are you talking about?
Old Dec 25, 2004 | 05:55 PM
trtturbo's Avatar
The only thing that proves is that the engine runs on vacume until boost hits. With the size of the silicone elbow, any LS1 will suck it in for a second even if it was through a cold air intake.
Old Dec 26, 2004 | 08:14 PM
99z20ate's Avatar
Theres nothing wrong thats normal, im not sure what the stock bov sounds like , but im sure thats what it is.
Old Dec 26, 2004 | 08:52 PM
okcss's Avatar
I have a turbo stang and i had that problem.I had a elbo made now it doesnt do that.
My ss made 400 hp and it never did that.I change it out!That is restricted my Lightning did the same at high boost.
