boost on stock intake??
Old Dec 28, 2004 | 11:24 AM
ls1boost's Avatar
Default boost on stock intake??
Can a stock ls1 intake handle up around 15lbs?? i have heard rumors of stock intakes craking...just wondering if this is true or not... I was thinking about going with the weiand intake if the stock one will not handle the boost...is this a good idea or not??
Old Dec 28, 2004 | 11:28 AM
SS00Blue's Avatar
Never heard of it. My car has seen 13 pounds with no problems. I definitely know many here had gone well beyond 15 pounds unharmed...
SC-
Old Dec 28, 2004 | 11:39 AM
98CustomSS's Avatar
Mike Brown and Steve Turley are running 25-30 lbs of boost on a LS6 intake and haven't had any problems.
Old Dec 28, 2004 | 11:48 AM
ls1boost's Avatar
a couple of people around here said that heard of the plastic cracking under high boost... i wanted to see if this is true or not... if it is i am going to go to aluminum... but i don't want to spend the money if i don't need to...
Old Dec 28, 2004 | 11:55 AM
Blackbird's Avatar
so then use the stock one and if it cracks, which I seriously doubt it will, THEN go buy an aluminum one. why fix something that isn't broken???
Old Dec 28, 2004 | 12:51 PM
MIGHTYMOUSE's Avatar
you wont crack it. its fine.
mine has survived spurts over 30psi and continuous 17+psi use over the last two years
Old Dec 28, 2004 | 01:01 PM
777's Avatar
777
yeah these won't crack...don't go pay money for the alum. intake...
Old Dec 28, 2004 | 01:16 PM
chris99gmc's Avatar
I would think that you would blow the gasket before you cracked the intake.
Old Dec 28, 2004 | 01:23 PM
BIGBOS's Avatar
15psi on my stock ls6....
no problems
Old Dec 28, 2004 | 01:58 PM
y2khawk's Avatar
Yep, my stocker saw 18ish when i still ran it. No worries
Old Dec 28, 2004 | 02:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
My LS6 intake has seen 18-21 psi.
Old Dec 28, 2004 | 06:51 PM
TwnTrboCE's Avatar
Yep, We have been to 30.5psi with no issues, except for the tires.
