Supercharger with and XER 228/228
Old Dec 29, 2004 | 06:21 PM
chaos's Avatar
Default Supercharger with and XER 228/228
I want to supercharge my car in a few months, but before I do, I wanted to find out if my current cam would work with a blower. The cam is a XER 228/228 .588/.588 on a 112+2 lsa. Would I have to swap my cam out and put in a smaller cam? Also, what would be a good blower to go with for low and mid range power?
Old Dec 30, 2004 | 08:02 PM
chaos's Avatar
Anyone?
Old Dec 31, 2004 | 12:25 PM
Got Me SOM's Avatar
it would work but it wouldn't be the best cam to use, on a blower car, you want a high lsa, minimum 114 but preferably 115 or 116.
Any blower will give you good bottom end torque, ATI or Vortech. Opinions vary. Use the search button lots of good infor already discussed already
Old Dec 31, 2004 | 12:35 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
That cam will have good low and mid range power. The 112 LSA will just (as compared to a 114) be done at a lower rpm.
Old Jan 1, 2005 | 11:01 PM
chaos's Avatar
The reason I don't really want to swap it for a different cam is because I love the way this cam sounds , but if it does come down to it, I just may have to get a cam with a higher lsa. Thanks for the info
Old Jan 2, 2005 | 03:32 PM
LS1Tech Co-Founder
In the end, who knows, you might just sacrifice like 10-20rwhp peak, but the midrange will be the same. It's not always about peak hp. Duration is more important than LSA for the most port, duration is what makes the power. If duration was the key then all the race cars out there would be running 115-119 lsa's and very few do.
Old Jan 2, 2005 | 03:48 PM
qqwqeqwrqwqtq's Avatar
What kind of power do you want to make?
You can make a lot of power with a lot less cam than that.
I disagree that a wide lsa makes more high rpm power, or more peak power.
LSA is a meaningless number anyway. All that matters is the actual valve events.
Old Jan 3, 2005 | 01:03 AM
chaos's Avatar
I'm looking for around 500-550 hp. I want something that'll kick in pretty good in the low to mid rpm's too.
Old Jan 3, 2005 | 01:09 AM
MelloYellow's Avatar
Do you have the Cam Card valve timing info to post?
Most likely the 112 has overlap.
Old Jan 3, 2005 | 01:29 AM
chaos's Avatar
No, I don't have it.
Old Jan 3, 2005 | 06:40 PM
slow trap's Avatar
i have the same cam as chaos i think,valve timing at .050 is =io 4*btdc ic44*abdc eo 48* bbdc ec 0*atdc installed at 110.0 centerline.oh yeah this one is a 112+2 if that makes a difference.this cam does decent on the jug also if that is in the plans chaos.
Old Jan 3, 2005 | 09:47 PM
chaos's Avatar
Thanks for lookin out slow trap
Old Jan 5, 2005 | 12:06 AM
chaos's Avatar
Thanks for your opinions guys, but this past week, I've been looking into the STS system a little more and I think I've had a change of heart . Thanks for your help though.
Old Jan 5, 2005 | 02:43 PM
Got Me SOM's Avatar
Old Jan 5, 2005 | 08:52 PM
chaos's Avatar
Originally Posted by Got Me SOM
What's wrong with the STS?
