Alright Lets solve this PCV issue right MEOW!
1)running lines underneath the car(oil mess all the time?)
2)AMW catch can and Check valve (which check valve and where to get it?)
3) ls6 PCV system, requires moving manifold
4) Metco breather
5) using system that ATI provides (shoots oil into blower???)
I would make this more general but I know jack about turbos.
I personally ordered the catch can from AMW. What do you think is the best setup and how did you do it. With pictures if you have them. I will get some AMW pictures up soon. But what check valve and where to get it and where do i put it.
Is there somewhere we could get a detailed explanation to get the big picture? thanks
If it makes people happier you can run the 3/8 line's to the air filter area,that will get rid of all the smell.These motor's were not designed to run FI so the venting is not designed to take out the extra pressure.PVc's work great for getting vapors out of the oil area.When running no PVC you do have to change the oil more.I like 2k miles on oil changes,but would do it anyway's with or without the PVC due to the stress of FI
Pssstt.. its PCV... not PVC... we dont have plastic pipe on our cars
Not trying to be an ***, just a pet peeve
Thats it. Almost 4 years and 37,000 miles now.
If you had a PCV valve which could withstand positive pressure, you would not even need that.
