Tell me what you think
Old Jan 6, 2005 | 02:12 AM
Solobarictahoe's Avatar
Default Tell me what you think
I got a 2004 gto i want to keep the lower end stock. I was thinking of going with patriot LQ9 heads stage 3 with 72 cc combstion chamber to make it about 9:1 with a D1 procharger at 10 psi help me out i wanna drive this on pump gas and i dont want nothin to break. Also i need help with a good blower cam i dont care about the idle. thanks for your help. let me know if what i said so far will work. thanks
Old Jan 6, 2005 | 04:55 AM
Slowhawk's Avatar
LS1Tech Sponsor
I live about 20-30 minutes from you and have alot of blower LS1 cars driving around.Feel free to contact me if you want to see any of them or take a ride to make up your mind.We specialize in LS1 cars.
Old Jan 6, 2005 | 10:22 AM
cool thanks i am just kinda confused i wanna make power but drive it everyday
Old Jan 6, 2005 | 10:29 AM
GrahamHill's Avatar
I would think that 10#'s through a nice set of heads would be too much for pump gas?? Irreguardless of compression ratio? But then again i'm here to learn and listen, not speak, lol!
But 10#s through stock heads on the other hand seems doable.
You'll need trans work though, lol. And a clutch...
Old Jan 6, 2005 | 10:31 AM
i would never put 10psi threw a stock head i would only do it if i lowered my compression i would do 7 psi threw a stock head
Old Jan 6, 2005 | 10:34 AM
GrahamHill's Avatar
What I was getting at was this... there is more air (volume wise) with a given amount of boost through ported heads versus the more restrictive stock heads.
Old Jan 6, 2005 | 10:45 AM
I see what your saying thanks.
Old Jan 6, 2005 | 11:18 AM
libertine1015's Avatar
I run 10# all day long through stock LQ9 heads and pump gas, of course you have to have an intercooler but thats a given. Im putting in a bigger IC this spring and will probably run 12#
Old Jan 6, 2005 | 03:37 PM
Slowhawk's Avatar
LS1Tech Sponsor
You can run 8-10lbs through your stock heads all day.It's all about the tuning.You'll be surprised how much HP you will make without the Cam or Heads.Just upgrade the valve springs with 918's and run a D1 at 8-10lbs.Easy 500rwhp and drives like stock.
Old Jan 6, 2005 | 03:40 PM
Wouldn't the compression be to high
Old Jan 6, 2005 | 05:15 PM
Wolfee's Avatar
Apparently not, otherwise he wouldn't have said it! Slowhawk KNOWS what he is talking about, if you want to go fast get in contact with him, if not, no biggie, just keep asking what if's!
Wolfee
Old Jan 6, 2005 | 08:33 PM
Bryan Wilkinson's Avatar
You will have no problem with this setup running on pump gas. I do it all day. Head selection is perfect on parameters. The key is keeping the charge cool. Dont do it without an intercooler. However, 10 PSi is pushing the reliability threshold on the stock bottom end. My friend and one other on this site have done more but it is not reliable. Positive crankcase pressure will cause oil problems with the stock bottom end. Cam needs a split on duration to keep boost in, 8 points or so, You need more lift on the exhast side than intake side, and LS is really up in the air. It has been said that 112 will give you better low end, and 115 will give better top end. Some Aussie buddies, state that 112 can be tuned to idle like stock. I have seen a video of a 108 that was very close to idle. You can email me directly if you want to go into more detail, at lunapark@perigee.net
