Results are in!!! DYNO SHEET HERE!!!! COME IN!!!
Old Jan 11, 2005 | 11:16 PM
  #41
GrannySShifting's Avatar
Predator03 is the coolest guy ever. LS1 power, we have 11 more pounds of boost to go, do you think we could squeeeze another 100 hp out of it to match his 03Cobra blower motor?
You are retarded. Your car is going to make more power under the torque peak, you have a twin screw supercharger. these guys are running centrifigals, make more peak power and are more effecient up to. How fast has your mid 600 hp car been? Your seem to be a tool who understands nothing about the internal combustion engine or power. Correct me if Im wrong. How much boost were you pushing to make 500 rwhp with your motor built for boost?
This guy isnt a tool, hes the whole fricken toolbox. Where is the limp hand and roll eyes smiley.
Old Jan 12, 2005 | 12:09 AM
  #42
CAT3's Avatar
Restricted User
osuhuntero7- damn long name, anyway very nice results, almost convincing me to avoid the lure of the turbo kits... So many ppl have seen either the high side of the Centri SCs power or the belt slipping/boost creeping/bracket flexing low side. Glad to see SDCE is making a badddasssss setup to go with the ATI's. Will be interesting to see how it works out with a built engine and more boost too. Good luck.
OT-I didnt see anything really requiring bashing Predators post. He complimented one setup. And also being he is twice screwed, may not be in the know on the fact that his setup will pull the power band to the left, and more flatline it than the Centri SC that make power in the higher rpm side of the band. Maybe his ingnorance is his bliss, but doesnt require all the bad mouthing.
Charlie
Old Jan 12, 2005 | 12:18 AM
  #43
LSs1Power's Avatar
Charlie
osuhunter07 is sharing his results with us and he is happy with it and this troll is knocking his car off because he has a Cobra that dyno'd higher... WHO CARES. If he posted his dyno sheet here i would have gave him props for his car, but knocking another's guy car because u have a higher dyno number is silly. Hell my friend with his 890rwhp pump gas viper enjoy looking at other dyno sheets and he doesnt act like an AH. That what pissed me off... And sorry for the language if i offended anyone by it. I will edit my post a little bit.
Old Jan 12, 2005 | 12:27 AM
  #44
Avengeance's Avatar
And Mustang guys wonder why they get the rep they have.... Ive only met a hand full of Stang owners that were actually decent people.
Old Jan 12, 2005 | 01:36 AM
  #45
badeSST's Avatar
He was poppin off at the mouth, so he needed to be mouthed.
Old Jan 12, 2005 | 01:53 AM
  #46
2FAST4U's Avatar
Not trying to be a *** hole but is it just me or are all these Supercharged LS1 numbers low. I mean the average is what 400-500hp? If I spend that money I want at least 100hp more. Stock motor Incon Twin Turbo I made 520hp and 590tq.
Again I say this not to be a *** but I don't understand. I mean I know there is a problem with the pulleys..... It seems that is costs more and makes less. is there something I missed? Is there a reason the supercharger is better even with lower power numbers?
Old Jan 12, 2005 | 01:58 AM
  #47
LSs1Power's Avatar
Im making 550rwhp 500rwtq with a procharger on a stock bottom end with only 8psi. Its how well u match your setup together, thats all. I dont have problems with the pulleys too.... That was along time ago with the ATI 6 rib setup.... Things has changed since then and i dont see anyone having problems with the new 8 rib setup from Procharger. When i have a forged bottom end waiting i will push the stock engine to the max on race gas.... otherwise i want it to be safe.
Old Jan 12, 2005 | 02:09 AM
  #48
2FAST4U's Avatar
See that sounds much better! But I always hear of SuperCharger problems, Mostly pulley but also brackets and maf. As well as the higher cost of the supercharger vs. the Turbo.
Sorry not trying to highjack the thread......
Old Jan 12, 2005 | 09:34 AM
  #49
osuhunter07's Avatar
o yeah, btw you car with the same mods as my car put down 5 hp more and 5 more TQ than mine.....................
Not impressed
Old Jan 12, 2005 | 10:48 AM
  #50
LSs1Power's Avatar
As i told u... There is no problems with the new 8 rib ATI SC in terms of belt slippage and bracket flexing. Those were the old days. Also SDEC came up with a good solution for the guys running the old 6 rib setup.The SC cost with cam was less than a good traditional turbo kit such as QMP or CAS.
Old Jan 12, 2005 | 10:51 AM
  #51
What did your setup consist of exaclty? How much boost?
Old Jan 12, 2005 | 12:28 PM
  #52
badeSST's Avatar
Besides the sts which turbo kit would be cheaper than an ati kit? You can get an ati d1sc for like 4100-4200 dollars.
Old Jan 12, 2005 | 01:17 PM
  #53
2FAST4U's Avatar
Well the Incon was way more than that but a TTI kit is like $3800 or $4200 with injectors and everything! right It has been a long time like 2 year? And with a turbo kit you don't need headers.
----Again a am not trying to be a dick just asking!----
--Hell could be wrong--
And boost is only a number. Air temp,flow, and power numbers matter more.
But I had the Incon kit (with much smaller different turbos) on a stock motor LS1. Boost was 10psi and 520rwhp. that is alot for a bolt on power adder on 94 pump gas. As harlan said "the Incons with the gates wired close only go to 12.5psi and in the upper RMP spike fast to 16psi but then right back down".
I just know of a few people personaly and some on LS1TECH that had lots of problems. But I am glad to hear they are fixed.
Old Jan 12, 2005 | 01:21 PM
  #54
2FAST4U's Avatar
Not impressed
Not the same mods at the time at all. those tubos where Incons Mustang kit turbos and maxed out at that. But we all know the big boy incons make much more power.
And the mods on my car have more than changed a little from then. **** I didn't even have the car that way for more than 60days before we rebuilt it bigger!
Old Jan 12, 2005 | 02:36 PM
  #55
No man i wasn't talking about you. I was talking about cobra boy. He had the same mods with a built motior as me and had 5 rwhp more. your car (cars) are sick
Old Jan 12, 2005 | 10:04 PM
  #56
Havok2's Avatar
well that predator guy is locally here and he put down a whooping 12.4 with that much rwhp :LOL:
Old Jan 12, 2005 | 10:07 PM
  #57
2FAST4U's Avatar
Oh cool! And if any of you guys race him post the video.
Old Jan 13, 2005 | 09:03 AM
  #58
badeSST's Avatar
Hahaha, thanks greenie, I figured it was somethin like that.
Old Jan 13, 2005 | 09:11 AM
  #59
NA$TY-TA's Avatar
HOLY CRAP..... I ran better then that with 322 rwhp..... wow i guess that extra 430 over really helps...........
Old Jan 13, 2005 | 11:37 AM
  #60
He cried when he broke his IRS, or so i hear from local guys. What a *****
