Need less boost. new crank pulley?
best way to go about this is too keep your foot out of it...serious.
With the SDCE set up we are bascially maxed on how big our crank pulley is, any bigger and the belt would start hitting other things due to how its routed. I asked this early on in the game when I had the MMS 6 rib crank pulley(7.8xx) and wanted to utilize it with the SDCE set up. SDCE rightly pointed out that the belt would not clear.
So shift early and keep it together that way...real easy with a 6 speed
J
FWIW I ran 12 psi on my stock 98 block for about 40 thousand...9 psi with a 50hp dry shot too towards the end with no venting of the block...in fact its still sitting intact in the garage right now....its all in the tuning with FI and longetivity...and respect don't get out of hand, you know what you're limited by now, stock internals
I would make sure the AFR is at least 11:1.........thats where mine is w/my forged motor, with right over 20 degrees of timing.....
if you are 12:1, that means you are close to 12:1 on the street......
Kyle
SC-
Your right..... i do believe fuel is pulled when you bounce off the rev lim... and under boost that would be bad.
Nick,
A cam will help the motor flow better ie dropping boost a bit but you should pick up some more power also...... then your 42# Injectors will be close to maxing out.......... How long till you do a cam??
Kyle
I will get the cam............. Once i get money. Story of my life. the 42#'s are maxed out right now. So I will have to do 60#'s the springs, retainers, oil pump, timing chain. RevXtreme, told me that they have a good blower cam they use on a lot of cars. It was I think a 224/228 0 overlap 113. Do you think a 224/230 114 cam would be better?
How much of the Ol cam sound do you want??? My 230/236 thats in there now sounds awsome on a 114LSA
Its a Comp XER 230/236 .598/.608 on a 114+4 LSA
On stock cubes how about a 226/232 .580ish/.590ish on a 114+4. Im a big fan of a 6 degree split. Make sure you buy double springs when you do. If it will fit in your car ill sell ya mine here in a bit if its doenst work well with the turbo ( i highley doubt it works well) Ill give ya a good deal... we just have to make sure you have enough piston to valve clearence.... i never checked on mine but im pretty sure with my -15cc dish im ok
Ill make soem phone calls and find out.Kyle
That rocks
That rocks
You do Big dog...... 15-16 psi thru that forged 348..... when you gunna dyno that thing and let us know what it makes.... i know you got enough Hp for a 10...... Hey BTW that
was in fun back at ya..... No hard feelings at all bro.
Kyle
I just want another engine. Maybe I should get some HP tuners to just take some timing and add some fuel? Or should i just wait till I get the cam and have them take more timing out and more fuel. I have the support brace ready to ship...please call me when you have a sec!
wendy
