Drill/Tap oil pan- any hints?
Hello. Is the oil pan of the LS1 tricky to drill/tap? I've read that it is powdered metal and I wondering if this poses a problem. Any special techniques needed?
Thanks
Ben
Thanks
Ben
when I drilled mine, I coated the bit in grease to help keep some of the shavings out of the pan. I also had to grind a little on the k-member in order to get far enough back to be able to drill a hole, I'm not sure if anybody else has had that problem. And be sure and not to be pushing to hard when the bit finally goes through the pan, the rotating assembly isn't to far away. Maybe some of the other guys have some more advice.
Closed ex-Sponsor Account
Thanks
Ben
Thanks
Ben
Ricky
Originally Posted by NXRICKY
Pull the pan and tap it off the car. a small peice of trash can destroy the bearings.
Ricky
Ricky
I drilled mine on the car. Just be really patient. Dip the drill bit into a tub of grease, drill for a few seconds, then wipe the bit off. Get a 1/2 inch drill and run it REALLY slow. If you take your time it is very easy to drill it without getting anything in the pan. Mine took about twenty minutes. Much quicker than pulling the pan, though.
-Geoff
-Geoff
TT-TECH Veteran
Well I will say this I drilled mine off the car but while I didn't use grease for obvious reasons. I didn't end up with much on the pan side I will say that it would be a bunch safer to take it off but the grease thing does work but I am sure you won't keep every bit out and what does go in the pan more than like likely the filter will get it if it gets past the pick up screen. It is your choice good luck.
