Turbo and cut-out
Old Jan 21, 2005 | 01:08 PM
kcshaner's Avatar
Default Turbo and cut-out
OK, this is my last exhaust post...I promise
I am having my car dyno'ed today and want to install my cut out before....should I install it or not? Should I see an increase in power over just using my Borla run open?
I can't decide if I will gain any power......
Old Jan 21, 2005 | 01:21 PM
Boostaholic's Avatar
I would install the turbo right after your downpipe where ever is convient (closer to the turbo) and dyno it cutout open. If you have like a few hours in pulls then do it both ways and post up your results.
Old Jan 21, 2005 | 01:31 PM
kcshaner's Avatar
I think I may just to that......thanks!
Old Jan 21, 2005 | 01:54 PM
SUPER DAVES Z's Avatar
You will gain power for sure. How much will really depend on boost levels and current backpressure. Don't be suprised if your a/f ratio's go a little leaner if you keep the same boost level. My guess would be at least 30hp gain.
Do it and let us know.
Dave
Old Jan 21, 2005 | 02:49 PM
cablebandit's Avatar
definitely add the cutout!!!!!!!!
Old Jan 22, 2005 | 12:55 PM
WestSide's Avatar
The shorter the distance the exhaust has to travel in a turbo application, the more power you'll make.
Old Jan 22, 2005 | 01:28 PM
vhgjk123's Avatar
I already had a cutout on my i-pipe from before the turbo. Without the turbo I gained like 2rwhp and .1rwtq. With the turbo and cutout open I gained 5rwhp and like 9rwtq. Not that great but its something.
Old Jan 22, 2005 | 07:57 PM
kcshaner's Avatar
Well, believe it or not.....my results are the following.
About two weeks ago with little tuning I was at 471 RWHP, Since then I opened up the Borla (no muffler) installed a cut out and my next run was 522RWHP
Final numbers ended up at 561 RWHP
Old Jan 22, 2005 | 07:59 PM
Sweet, did you do a straight cutout closed / open run to tell the difference without other factors?
Old Jan 22, 2005 | 08:08 PM
kcshaner's Avatar
No I didn't
I wanted to but the shop was already closed and they were working after hours, plus I was more focused on getting a good safe tune.
I did notice about 1 to 1/2 lbs more boost on the gauge with the cutout open, and it spools better. Best $35 I ever spent
Old Jan 22, 2005 | 10:36 PM
bud8fan's Avatar
im gonna dyno it both ways when i go up to allens around the 3rd or 4th...
Old Jan 24, 2005 | 09:58 AM
Very nice gains. I knew it would make a pretty good difference but 90 hp, that's huge! Definatly good bang for the buck mod.
