BOV and ATI??
thanks
mike
thanks
mike
Now for the BOV....most all BOV's will work for what your wanting. So it really comes down to preference. Coincidently I just posted to some fellow Procharger guys my new set-up with an ATI Raceready BOV that I had polished and installed in my plenum. The plenum is one of the best places to locate a BOV. Your close to vacuum sources and bleeds off the air right before the throttle plate. Good luck I'm sure some of the other guys will chime in on this!
Here's the thread I just posted on mine.
https://ls1tech.com/forums/forced-induction/265936-paging-bos-kyle-tom-forcefed-update-pics.html
Mark
You can find em for 239 at jegs or summit and you have to buy a flange from vortech, but its only 11 bucks. You will have to do some welding but that's cake.
http://home.comcast.net/~jsbird1998/mondoatthetrack.mov
http://home.comcast.net/~jsbird1998/mondo.mov
J
thanks.
mike
Kyle
Kyle
mike
Link is fixed, Kyle is right. Also a bypass will vent all the time no way around it. NOW for sound control, just route it back into the intake and that should quiet it down a lot or make a muffler for it like a few others have. Mine isn't bad at all because its so far down(behind the driverside fog light) Once the car is in OD you can barely hear it. But I like things a lil louder than others so it might not be the valve for you. IF you plan on pushing 15+psi make sure you get a valve that flows enough air for it.
But it will vent all the time, ATI or Vortech bypass valves..except WOT. It's up to you how you route em e.g. to atmosphere or back into the s/c...with the ATI you can only vent to atmosphere FWIW.
J
J
If $$$ is a big thing go with the Vortech "MONDO" (Did i say it good enough for ya Jer... inside Joke) its not that loud in overdrive and part of the fun is letting everyone know what ya got...........
Kyle
Please post up a link to the ATI piece as I am really interested in the recirc kit for it.
Kyle Exactly...plus you are ready to add a hose to recirc the vented air if you wanted.
J
http://procharger.com/component_photos.shtml
