too rich costs power?
http://www.innovatemotorsports.com/resources/rich.php
Being a heavy truckId take the airfuel to where most seem to like but leave your timing a little conservative
Tom
I'd also like to know what is better. I'm running 11.3-1 with 17 degrees of timing. Would it make more power at 12-1 with 15 degrees?
Parish, since it's so easy for you to change your tune with megasquirt, why don't you do a test.
--G-tech at 10 psi, 11-1 air fuel, and as much timing as it will take without KR
--G-tech at 10 psi, 12.5-1 air fuel, and as much timing as it will take(I'm assuming it will take less timing?)
But timing makes power.
I'd tune a max effort ride to 11.5:1 and as much timing as makes sense.
Good luck.
Charlie
i will try just what you sugested. 11.0-1 and vary my timing from 12-20deg or so and see what pulls the best, ALWAYS WATCHING FOR KNOCK.
then goto 12.5max but probably more like 12.2 or 12.3 and do the timing again. keep the runs all the same and just look at my 60-100 ET.
there are a lot of theories on timing too. i like the theory where it isn't "the most you can run without knock" as it is "the timing that makes the best power"
A/F I bet it is the same deal with a turbo, but just pondering here...A turbo runs off of exhaust heat and leaner burns hotter. Would you want a bit leaner down low for spool up? I haven't read anything about this, and it probably isn't the right line of thought even though in theory it may sound good.
While you might be tempted to run at LBT for power, the EGT's might be to high for the exhaust valves to live.
I personally spark it to make power, and add fuel to keep the EGT's below 1650° at the port. Just my $.02
As a motor gets near peak effeciency timing requirements usually will drop. max inj pulsewidth will be right where torque peaks
You melt **** before it ever detonates
