electric oil pump
Old Jan 28, 2005 | 01:40 AM
camrsz's Avatar
Default electric oil pump
Has anybody ever used some kind of electric oil pump to supply the oil to the turbo or turbos?
Old Jan 28, 2005 | 02:09 AM
StreetCruiser's Avatar
I used a Mocal on my truck, which died (pos), and now I am using a Westech with great results.
Old Jan 28, 2005 | 07:42 AM
Dustin Mustangs's Avatar
Why would you use one to supply the oil? Easy enough to find a pressurized source isn't it?
Old Jan 28, 2005 | 08:38 AM
DaveSchott's Avatar
Use the engine oiling by tapping into the plate above the oil filter. Do a search, it's been discussed 100's of times.
Depending on turbo location, you may need an electric or mechanical pump to move the oil from the turbo output back to the oil pan.
Also See the faq which is stickied here:
https://ls1tech.com/forums/showthread.php?t=208864
Where can I tap and return oil on the LS1?
There is a number of places you can tap and return oil on the LS1, here are a few of them.
Tap Locations:
Above the oil filter, there is a blockoff plate that you can get filtered pressurized oil from.
Old Jan 28, 2005 | 11:11 AM
camrsz's Avatar
im just wondering if its been thought of and tried? My turbos might be mounted down low, so i might need one for the return.
Old Jan 31, 2005 | 04:37 PM
3800SII's Avatar
Try www.engingearonline.com They have one that costs about $200.00
Old Jan 31, 2005 | 04:42 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Link did not work for me.
Ricky
Old Jan 31, 2005 | 07:21 PM
libertine1015's Avatar
http://westech.home.mindspring.com/propages/scvpump.htm
Old Feb 2, 2005 | 01:21 PM
3800SII's Avatar
Oops, it is www.enginegearonline.com it is a 12 volt gearpump like the one
STS kits use.
Old Feb 2, 2005 | 04:16 PM
spanktu's Avatar
that westech pump is a shurflo water pump
you can find them at northerns online store
Old Feb 2, 2005 | 04:24 PM
860 Performance's Avatar
Weldon pump makes some nice pumps specifically for pumping hot oil. I have used the 9200A and have no complaints.
