DYNO GRAPHs COMING SOON
Old Jan 28, 2005 | 07:54 PM
KAOS's Avatar
Default DYNO GRAPHs COMING SOON
just sent my graphs to cannibal to host for me. this was when raymer tuned it. one was with 8-9psi and pump gas and the other was 11psi and turbo blue. should be up soon. new graphs will be up within a week or two. will we see a difference?
Old Jan 29, 2005 | 07:33 AM
Scalpel's Avatar
Here it is, Daniel, you sent me the same graph 5 times.
Old Jan 29, 2005 | 08:53 AM
onfire's Avatar
Coal Mining Director
Are you using Alky? The A/F looks a little wacked if not as a dynojet doesn't load the engine like the street does. Good hp for 8 lbs.
KAOS's Avatar
you didnt get the "race" tune one? oh well i will send it
Old Jan 29, 2005 | 08:54 AM
KAOS's Avatar
no alky, it is a little funny looking aint it. pretty sure that pull was 9psi. he just didnt change it on the dyno.
Old Jan 29, 2005 | 12:58 PM
Scalpel's Avatar
Here's the race tune. Daniel, you're saving all your scanned dyno graphs under the same file name, jackass.
Old Jan 29, 2005 | 02:03 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
On your race gas tune you make peak HP at 4300 rpms? Neat. Can you feel it fall off at say 5000 rpms?
Old Jan 29, 2005 | 02:10 PM
goober35's Avatar
Man he is peaking at like 4000-4300 you need to do a A/R change on the turbo so that thing will spool later. Damn man that thing must have some pick up though.
Old Jan 29, 2005 | 02:20 PM
LS1Tech Co-Founder
Oops I read it backwards, the image is so big that I have to move around to see parts of it.
Old Jan 29, 2005 | 02:21 PM
foff667's Avatar
LS1TECH Sponsor
unless im missing something it looks like hes making peak power at 5200 rpms and peak tq at like 4000-4200
Old Jan 29, 2005 | 02:22 PM
foff667's Avatar
LS1TECH Sponsor
just always know before the 5250 mark tq will be above hp and vice versa after that point.
Old Jan 29, 2005 | 02:53 PM
goober35's Avatar
We also have to remember that this is on a dyno where you can not load the motor as well as the street.
Old Jan 29, 2005 | 03:18 PM
Scalpel's Avatar
Fixed the size.
Old Jan 29, 2005 | 03:51 PM
KAOS's Avatar
warbird told me it had a .96 a/r. thats what i am going off of
Old Jan 29, 2005 | 10:48 PM
KAOS's Avatar
Default paging warbird
hey this turbo does have a .96 a/r, right? not saying you would lie to me but this kit was setting at a shop for a while with out you watching it. no chance anything got switched did it? and not pointing fingers at anybody i just want to make sure
Old Jan 30, 2005 | 12:13 AM
Warbird's Avatar
The turbo is a PTE T74 Q-trim with a .96 AR housing and thrust mount bearing. That is what Rob said he sent me and I never questioned it, as I didn't feel it was neccesary. I gotta ask why, is there any question?
What I can tell you without doubt is the turbo I sent you was the very same one that came off my car. I did learn that the log manifold was incorrect very recently (I was never aware that the header exhaust tubing was undersized. Just to clear that up, I was sent a second manifold not because there was a question of size but because the first one was welded upside down with the exhaust housing pointing upwatds.
I might have to have a chat with Al Noe on that issue.
That dyno graph looks just like mine, except power dropped off hard at about 4500 RPMvand I could feel the stall. Looking at what I am seeing there, you are pretty close to falling out of your efficiency range.
Call me if you want to discuss the kit again.
Old Jan 30, 2005 | 01:46 AM
MIGHTYMOUSE's Avatar
get it dynoed independently
Old Jan 30, 2005 | 08:12 AM
onfire's Avatar
Good point.
Old Jan 30, 2005 | 08:47 AM
KAOS's Avatar
im gonna to. i didnt think it peaked early but hey who am i. to my knowledge its a .96 ar. how would i tell? i think some one is reading it wrong. the tq peaks at like 4k. does that change anybodies opinion of what is going on
Old Jan 30, 2005 | 10:30 AM
it will say .96 on the exhaust housing somewhere up in there. i'm sure it is.. warbirds car probably would make boost at idle with a smaller a/r.
i think the graph is representative of a qmp system on a stock cid engine and 76mm w/ .96 a/r
