tip for a supercharger
Old Feb 1, 2005 | 03:03 PM
jerrad's Avatar
Default tip for a supercharger
i read that if ou belt is slipping when making 1/4 mile passes just put a little vht on the underside of the belt that touches the pulleys and that should fix it for a few runs.
Old Feb 1, 2005 | 03:47 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Don't you think that would make a mess?
Old Feb 1, 2005 | 03:52 PM
MelloYellow's Avatar
I've heard of people doing that for back to back dyno runs. On the street/track, belt dressing is definitely a band-aid for poor wrap/tension.
Dynojets are harder on belts than the street is. The RPM's tach up faster and the belt rev's faster which causes more belt slip and orbiting/jumping issues.
Another note: Alum flywheels can have a minor effect of exacerbating belt issues by rev'ing faster too.
Old Feb 1, 2005 | 04:50 PM
jerrad's Avatar
from what i heard you just put a little dab. not enough to coat it or anything.
Old Feb 5, 2005 | 11:32 AM
mdhmi's Avatar
You're better off going with a good tensioner and really taking your time to get all of the pulleys aligned perfectly. A DynoJet doesn't have the same load as running on the street.
Mark
