Pushing the envelope
Old Feb 2, 2005 | 07:39 PM
Jammer's Avatar
Default Pushing the envelope
So, the rear mount twins are getting close, but as the ic pipe is about to be completed...I had a brain fart that smelled funky. What if I ALSO put on a D1 pro-charger. I get the pro-charged boost and the sts stlye twin turbo boost...how would the charged air fight each other if I pumped them all to the same intercooler?
What am I missing...
This is starting to become interesting again.
Old Feb 2, 2005 | 07:41 PM
KraZy's Avatar
I would think the extra hp loss on the crank isnt worth it.
Old Feb 2, 2005 | 07:42 PM
Boostaholic's Avatar
I think you would want to feed the boost into the procharger from the turbos if you were to use both.
Old Feb 2, 2005 | 07:52 PM
2002yroneformula's Avatar
I'd thought about doing this on my truck by running the STS as well as the D1-SC but I think it'd be a tad bit of overkill, plus for the boost it'd end up running I don't want to deal with having to build my motor to take it right now.
Old Feb 2, 2005 | 08:06 PM
fash00's Avatar
Do It
Old Feb 2, 2005 | 08:15 PM
Camaro_Zach's Avatar
yeah youd have to feed the blower into the turbos...however i doubt it will be worth the money. id rather invest that kinda cash in afr heads or a solid roller setup...or even in like thirty 55 gallon jugs of 112 unleaded
Old Feb 2, 2005 | 08:18 PM
got_hp?'s Avatar
the only reason to do it is the "cool factor"
tuning would be tough, and extra piping rediculous
Old Feb 2, 2005 | 08:20 PM
1bad2k2ta's Avatar
If you build it, they will come....
Old Feb 2, 2005 | 08:31 PM
dynedta's Avatar
chronic masturbator
jammer you have boost on the brain, but I have a better idea sts twins to f1 procharger into twin screw. things that make you go hmmmm
Old Feb 2, 2005 | 09:21 PM
Jammer's Avatar
I get the point guys, told you it was a fart of sorts. Chance are that I'll run this system for 05 and do something different for 06... Its just too much fun to design... when a job gets anywhere near completion, I get off onto a tangent. Gotta stop that.
Old Feb 2, 2005 | 09:27 PM
LSONE's Avatar
cant you get an intercooler that goes 2 into 1? i thought i saw one of those some where. i tell ya what, go ahead and buy the procharger, and if it doesnt work, i'll take it off your hands for you, free of charge!
Old Feb 2, 2005 | 09:39 PM
Yeah, but it wouldn't be too efficiant with a D1 into 1 outlet and twin turbos into the other, pressure should be equal on both sides (or close)
Old Feb 2, 2005 | 11:05 PM
Jammer's Avatar
I have that type of IC, could make an aluminum collector and put all into 1 then split to 2. Blower might help scavenge the turbo air
Nevermind, I have a headache.
