Q's on sts kit
Old Feb 7, 2005 | 05:23 AM
everx's Avatar
Default Q's on sts kit
hello im a bit new to this fourm. i had a question about the sts kit. first off i have a 98 Z w/ catback slp and a lid (i kow not much). but i was wondering exactly what else will i need to support the extra power gains. also what will i need to jack up the boost to 7 psi and will me car handle 7psi with out having to go meth or bigger injectors as well as blowing it up or breaking my drivetrain? any info would be greatly appreciated thank you.
Old Feb 7, 2005 | 05:31 AM
Slowhawk's Avatar
LS1Tech Sponsor
You should run bigger injector with just the basic 4-5lb kit.The only way to run 7-8lbs is bigger injector's(42lb) Front mount intercooler or Methenol.
Old Feb 7, 2005 | 07:03 AM
everx's Avatar
with bigger injectors ill have to get a bigger pump right? does any one know of any packages that i can get that comes with every i need to upgrade the fuel system? also would the stock motor be able to handle thosekinds of power gains? well thanks for the info.
Old Feb 7, 2005 | 08:32 AM
PurEvl's Avatar
Stock motor should be fine if its tuned correctly.
Old Feb 7, 2005 | 10:56 AM
F8L Z71's Avatar
12 Second Truck Club
Racetronix sells the injectors and you can probably get the pusher pump from them too.
No 7psi for you unless you have an intercooler or meth..
Old Feb 7, 2005 | 12:10 PM
Slowhawk's Avatar
LS1Tech Sponsor
We've run cars with 8lbs,42lb injector's and stock fuel pump without problems.This is also stock longblock motor's.Shoot me a PM and I can hook you up with everything you would need to run safe.
Old Feb 7, 2005 | 12:18 PM
FormulaFire's Avatar
go to www.trtturbo.com. Billy is an amazing guy and will help you out. They have packages that contain the bigger injectors a fuel pump. He also has an intercooler in one of the packages. Great guy to deal with and best prices I've seen. he can answer all your questions.
Old Feb 8, 2005 | 01:51 AM
everx's Avatar
wow thanks for all the replys they have helped out alot.
