396 cubic inch lt1 with t76
Old Feb 8, 2005 | 12:44 AM
camarosf's Avatar
Default 396 cubic inch lt1 with t76
how fast do you think this combo should be able to go ? it is Motor: 396 with 9.4:1 cr, 4 bolt splayed caps, canfield heads that have been fully ported, custom turbo cam by Comp Cams intake an exhaust is 230-235@50 , 544-555 on a 114 , r series lifters, Ferrea valves, Callies crank, JE pistons, Oliver Rods, 58 mm tb, #65 injectors, F.A.S.T. tuned by Harry Hruska at Precision, Walbro 340 fuel pump, electric water pump, T76 turbo, custom 1 3/4 headers, intercooler, 3 1/2 dp to 3"SLP exhaust . 6 speed with mccloud twin disc and 3.50 gears in 9 in. it is in a stock weight 94 camaro .
Old Feb 8, 2005 | 05:24 AM
smokinHawk's Avatar
should be able to hit low tens, top nines.
Old Feb 8, 2005 | 10:00 AM
got_hp?'s Avatar
many people are running 9s with less powerful setups.......properly tuned suspension is what it takes.
Old Feb 8, 2005 | 10:37 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Not enuff info!
-gas?
-car weight?
-slicks?
Old Feb 8, 2005 | 04:41 PM
camarosf's Avatar
what other info do you need ? i will post it .
thanks
Old Feb 8, 2005 | 04:49 PM
LS1Tech Co-Founder
Originally Posted by camarosf
how fast do you think this combo should be able to go? it is in a stock weight 94 camaro .
-What gas are you tuning on?
-Slicks, drag radials or street tires out back?
Old Feb 8, 2005 | 05:02 PM
camarosf's Avatar
will be on race gas for racing . tires will be et streets or 10.5x28 slicks
Old Feb 8, 2005 | 05:43 PM
LS1Tech Co-Founder
Full weight car with driver, I say 10.0-10.5 on slicks. Need to propel a 3700lb raceweight down the track.
Old Feb 8, 2005 | 06:10 PM
camarosf's Avatar
car has tubular K member , spohn torque arm ,lower control arms and subframe connecters . do you think the fuel system is enough ?i would like to run 9s and drive it to and from the track . any other suggestions or comments ?
Old Feb 8, 2005 | 06:17 PM
Warbird's Avatar
396 w/T76 will peak at about 4800-5100 and fall off hard after that. Not enough turbo for a big motor.
Old Feb 8, 2005 | 06:38 PM
NumberOneSled's Avatar
Any dyno numbers?
Old Feb 9, 2005 | 02:23 AM
krazy_ws6's Avatar
When would a T 76 max out on a 427.
Old Feb 9, 2005 | 08:55 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Krazy, you can use the info below to find out how a 427 and T76 would do. Keep in mind that is a map for the older T76's....
http://www.forcedinductions.com/consumption427.htm
http://www.forcedinductions.com/imag...20maps/t76.jpg
In case you don't know how to use the info above, you can use this link below..
http://www.forcedinductions.com/help.htm
Jose
Old Feb 9, 2005 | 06:33 PM
camarosf's Avatar
i picked the car up today and it is plum cool . makes great power and it is only making 7 lbs with the controller turned down
Old Feb 9, 2005 | 07:00 PM
gnx7's Avatar
Running a single Walbro 340 and a T-76 is asking for trouble. I'd say you need to run (2) Walbros (one on a Hobbs pressure switch) if not a big single pump.
Better safe than sorry with forced induction and your fuel system.
Where are you located?
-GNX7
Old Feb 9, 2005 | 08:38 PM
camarosf's Avatar
kentucky
Old Feb 18, 2005 | 03:08 AM
camarosf's Avatar
here are a few pics
Attached Thumbnails 396 cubic inch lt1 with t76-mvc-012f.jpg   396 cubic inch lt1 with t76-mvc-013f.jpg   396 cubic inch lt1 with t76-mvc-019f.jpg
Old Mar 7, 2005 | 10:18 AM
camarosf's Avatar
took car to track yesterday with it set on 10 lbs and went
60 ft 1.620
330 ft 4.598
660 ft 7.006 mph 102.51
1000 ft 9.081
1320 ft 10.810 mph 130.82
i was on 26x10.5 et streets .
Old Mar 8, 2005 | 06:56 PM
RealQuick's Avatar
Nice times. Any hp/tq numbers? Where is peak boost (rpm?) and where is peak hp at?
Old Mar 8, 2005 | 07:22 PM
camarosf's Avatar
no dyno numbers . i would say it was at 10lbs by around 3500-3800 rpms . the next time i go i am going to try some race gas and turn the boost to 15 lbs and see what happens . i hope the track is a lot better because it sucked sunday .
