Need Incon Part - Anybody Got It??
Old Feb 12, 2005 | 10:51 AM
ChevyNo1's Avatar
Oh, I'm gettin it now. I actually have a breather filter cap where the oil cap usually goes on the passenger cover . . . we're achieving the same thing.
- Dug
Old Feb 12, 2005 | 04:51 PM
red ws6 99's Avatar
- Dug
Incon put the port on the valve cover that went to just behind the throttle body and routed it the inlet line. I don't run it that way since I don't want to clean it out intercooler that often. You should not get any oil dripping out of the intercooler or compressor housing unless you have loose connection, which means you are also loosing lots of boost. If the check valve is stuck open on the oil supply you will get oil out the exhaust on startup and then it should go away. The seals on the turbo only prevent oil leakage when the turbo is spinning.
Gary
