Oil pressure problems solved!
Old Feb 11, 2005 | 02:11 AM
Boostaholic's Avatar
Default Oil pressure problems solved!
I don't know how many of you have seen this before.
My oil pan gasket did not make a good seal around where the filter send and return area were, and oil was leaking back into the pan from there.
After some thought on it last night I came up with that, got a new gasket, put it on, torqued the pan back down, boom 60psi, hooked the turbos back up, 50-60 psi again, killed the motor and shut down shop. Its always a relief to fix a problem serious as low oil pressure, the good news is the motor had at least 20-30psi when it was leaking oil, and it only ran for a few seconds at a time a few times, so I really doubt there was any damage.
Old Feb 11, 2005 | 05:42 AM
WestSide's Avatar
Old Feb 11, 2005 | 05:59 AM
smokinHawk's Avatar
well good you found it and didnt damage anything. ad it was a simple fix
bythe way have you got recent picutes of the set up, we still all want to see.
Old Feb 11, 2005 | 10:12 AM
Yes, I will be sending you some tap and return pics for the FAQ and taking a lot more pictures later.
I just don't want people to see my gheto wiring right now, there are wires running all over the car while its in a "testing" on jack stands state, hell we even have a autometer oil press gauge mounted in the bay.
Old Feb 11, 2005 | 12:34 PM
Fullthrottledan1
Guest
Posts: n/a
Thats good to hear it wasnt a major problem. congrats
Old Feb 11, 2005 | 03:55 PM
Got Me SOM's Avatar
interesting, how low was your oil pressure before the fix. Caveman you should check this out before ripping your motor apart tomorrow.
Old Feb 11, 2005 | 04:05 PM
20psi @ 1000rpms
Old Feb 11, 2005 | 04:14 PM
Got Me SOM's Avatar
interesting my friend caveman is having a similar problem.
Old Feb 11, 2005 | 04:30 PM
Armageddon's Avatar
...with cheese.
glad you got it fixed man, and thanks for sharing all your fixes to problems that any one of us could run across. It might help later. I really don't think 20-30 psi for just a couple minutes would hurt anything btw...
Old Feb 12, 2005 | 12:39 AM
Caveman's Avatar
10 & 11 Second Club
Yes that sounds similar to my problem but my oil pressure was going down to 10-15psi at 1000rpm. My engine also had about 350- 400 runs on it over a 3 year period before the Vortech, so it would be good to do new berings and rings anyway.
Old Feb 12, 2005 | 09:49 AM
Got Me SOM's Avatar
I'd try tightening it up to see if that does anything, and then for the hell of it take it to NO Bull and blow it up there!
Old Feb 12, 2005 | 11:25 AM
That won't fix it, the 2 holes through the gasket have kind of a oring like shape to them and if they are too compressed to the point where they are leaking, it won't hold from what I can tell.
