PROCHARGER: is anyone having pulley aligment problems or its just me?
Why dont u guys switch to a 8 rib instead of 12 rib and see how it goes. The Viper, Vette and some F-body guys are running 8 rib setups and pushing close to 900rwhp with no problems. Maybe its just the universal 12 rib setup that is not working for u.
Originally Posted by MelloYellow
Laser Belt Alignment Tool from Gates sure made it easier for us working out alignment bugs.
Good Luck,
Mark
after replacing a crank/s/c pulley, harmonic balancer which i guess is more expenisve for lt1s cuz i paid 160bucks and thats 15% off list, ati pulley was another 215$ everything seems to be straight i took the car out, did a few blasts seen 10-11psi at around 3500rpm a few times, then some 5psi pulls, i probably got into it total of 12-15 times pulled the car back in the shop and the belt is spotless, hopfully it stays that way
. I can still see a hair movement in the s/c crank pulley but i dont think its possilbe to have it perfectly straight when the pulley is that far off the crank. All in all so far so good
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
