Remove MAF Screen?
Old Feb 15, 2005 | 10:23 PM
CMKworm's Avatar
Exclamation Remove MAF Screen?
Is this recommended for a supercharged car?
Old Feb 15, 2005 | 10:27 PM
qqwqeqwrqwqtq's Avatar
IMO, if you're using a MAF sensor, than there is no good reason to modify a stock screened sensor.
Old Feb 15, 2005 | 10:29 PM
Boostaholic's Avatar
I had bad luck after removing my screen, I would not recomend doing it.
y2khawk's Avatar
Last thing you wanna do is mess w/ the PCM's source of info for fueling and advance when boosting.
Do yourself a favor and leave it alone. Less to worry about when tuning
Old Feb 16, 2005 | 12:21 AM
97 Z Me Go's Avatar
All I ever hear is bad things about descreen MAFs
Kyle
Old Feb 16, 2005 | 12:56 AM
Mike 01WS6's Avatar
Anyone have a STOCK unscreened MAF they'd be willing to part with? I have a unscreened ported MAF that is gonna be in the garbage soon.
Old Feb 16, 2005 | 06:25 AM
2001WS6Vert's Avatar
Which MAF should I get if I want a larger diameter one (85mm)?
Old Feb 16, 2005 | 09:37 AM
kcshaner's Avatar
I have been contimplating this to, I would love to know. It seems like in the higher HP FI cars with an emphasis on larger TB's, ported intakes, etc., the stock screened MAF would be significantly restricting airflow and the potential of these parts. In my experiences with Mustangs They had several MAF's to work with FI and NA cars that were much better then stock (ie. lightning MAF, C&L, etc.)
Wouldn't there be a significant increase in power by upgrading the stock screened MAF?
Old Feb 16, 2005 | 02:37 PM
kcshaner's Avatar
TTT because I am hoping for some info
Old Feb 16, 2005 | 04:39 PM
LS1 SPEED INC.'s Avatar
Not if it's run on the pressure side. We've made around 850rwhp through a stock screened MAF sensor fwiw.
-Jim
