head/cam swap OR supercharger???
internal:224 cam Thunder racing with new ported heads and perfect tune
Supercharger: split between procharger or Vortech around 7-9 pds of boost
I know the head and cam setup will be cheaper and give me about 375rwhp and ive already got all the good bolt ons...not sure how much rwhp the supercharger will give me, ive heard 40 percent of stock power?
CONCLUSION:which is easier on the engine(lookin for 100,000 miles...i also realize about cam maintence)and how much more will the supercharger give me compared to head and cam???
It will run u between $5000 to $6000 with the fuel pump, injectors, installation and tune. U can run anywhere between 7-12psi. Bob at EPP is running 15psi on his stock 128K miles engine with no problems. It all depends on the tune. U will need a intank fuel pump and injectors. Good luck.
I would think you would be making roughly the same amount of power after either one. I would guess somewhere in the 400-430 range if you already have some bolt-ons.
All I know is that I ran a Vortech blown C5 at the track last summer and even with my shitty home-made tune I had him until the last 10 feet of the track where we ened up within .03 seconds of each other. Seems like you would expect traps in the 116-123 range depending on if you did a cam with the blower etc.
I went H/C and figured if I wanted more I'd go N20... That's why I did the TSP 231/237. I really can't go blower at this point without changing the heads and the cam. If you go blower first you can always add cam, heads or N20 on top of it later.
something to think about...
If u want to drag race with sticky tires, a bolt ons LS1 will need a good clutch and rear end let alone H/C or BOOSTED LS1. I broke two SPEC clutches before the SC and the Mcloed is slipping after the SC. I also changed to a 8.8 rear end because the 10 bolt took a detour before the SC lol.
hahaha and yes surr 430 rwhp with cam only street car man i had the cam in my car its done by hpe and it idles fine and drives fine dummy o and let me know how long that motor lasts pushing 550 rwhp on a blower with stock internals
