SMC alky guys inside please.
Old Feb 19, 2005 | 05:56 PM
PlowTown Missile's Avatar
Default SMC alky guys inside please.
Are you guys running denatured alcohol or methanol? Which is better to run?
Old Feb 19, 2005 | 05:57 PM
MelloYellow's Avatar
Methanol.
Old Feb 19, 2005 | 06:28 PM
Originally Posted by MelloYellow
Methanol.
Can you run straight methanol or do you have to mix it? I'd like to be able to run it straight.
Old Feb 19, 2005 | 06:37 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default meth
straight meth here.
Old Feb 20, 2005 | 06:53 AM
2001WS6Vert's Avatar
Does anything have to be changed with the flow rate or nozzle between the two (denatured vs meth) or do you just put the meth in?
Old Feb 20, 2005 | 09:27 AM
cablebandit's Avatar
just put it in...monitor knock and a/f . Personally i would/do use methanol. it is cheap and very effective.
Old Feb 20, 2005 | 05:37 PM
Syclone0044's Avatar
Default Methanol
I have the round bottle SMC and was warned to not use pure methanol, for it would eat the pump seals, well the pure methanol is so good in terms of the boost/timing I can run compared to denatured that I run 100% methanol exclusively anyway, and my pump is still running strong and setting ET/MPH records for the combos I have run. (Knock on Wood).
If you go to www.turbobuick.com in the Alcohol Injection forum they have a post saying "Methanol Sources" that will list places around the country and the price to buy methanol. When I buy it in 6 gallons or more at a local race fuel dealer it cost 1.75 a gallon Trust me a 5 gallon tank will last a LONGG time like all summer for a frequent cruiser.
Old Feb 20, 2005 | 06:04 PM
True. Not sure about SMC's compatibility with 100% Methanol.
I know Alky Control/Julio's kit is designed for 100% Meth.
http://www.alkycontrol.com/
Old Feb 20, 2005 | 06:45 PM
I talked to Steve at SMC friday...main thing is for it not to sit. I hit the test button every day I drive my car just to keep the pump freed up
Old Feb 20, 2005 | 08:18 PM
Sandmann120's Avatar
Where is Edwardsville? I live in Central IA and get methanol for about $1.40 or less. I buy mass quanities at a time, so I might be able to hook you up.
Old Feb 21, 2005 | 11:26 AM
BRENTT94Z's Avatar
I hear rumors that if you leave meth in the containers for a period of time it will gum up if moisture/condisation mixes with it. Is this true? Can you leave the meth in the tank w/ out worries of corrosion or eating seals? Also how much improvement is their between Alk Vs: Meth?
I'm using some NOS solenoids. Do I have to use the fuel solenoids or can I use the nitrous solenoids. I dont see their being any problem other than flow.
Any suggestions??
Thanks
Brentt
Old Feb 21, 2005 | 09:48 PM
Methanol can draw water if it sits too long. Thats why people don't usually buy it in mass quanities. And yes, if it gets cold, methanol begins to 'gel' and doesn't flow as well.
