Big FI cam
Old Feb 19, 2005 | 06:12 PM
JerikSS's Avatar
Default Big FI cam
What do u guys think about this cam, to be run with 918's and hardened 7.35 pushrods and stock lq9 heads on an otherwise stock ls1 motor.
234\239 .598"\.612 115 lsa
I will be running a procharger set up with custom front mount intercooler and at around 8psi
What do u guys think? Will it be okay, or is the cam to big?
I cant wait to get all this on my car......
Old Feb 19, 2005 | 06:28 PM
goober35's Avatar
first of all the comp 918's springs are rated at .600 lift. And can go to 610 but if you go to 612 you will break a sping in a week easy.
Old Feb 19, 2005 | 06:42 PM
gator's 99TA's Avatar
i would go with a good port for forced induction.
in my 383 i am running a 237/245 on a 114 lsa
Old Feb 19, 2005 | 07:15 PM
JerikSS's Avatar
I am trying to get good tq #'s. What kin of results do u think this will give me?
Old Feb 19, 2005 | 07:31 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
i'm in the process of installing a similar custom cam in my car with more duration on the exhaust and on a 115. hopefully i will get some good results with it. 918's should not be used with that cam, i'm using patriot golds with my setup. why are you going with the 7.350 rod 7.400 is ok with that cam and stock heads and shortblock.
Old Feb 19, 2005 | 07:50 PM
JerikSS's Avatar
are u running a blower or just na.
Old Feb 19, 2005 | 08:11 PM
with an ati
Old Feb 19, 2005 | 11:08 PM
red90cobra's Avatar
you will kill the spring in a week. And then you'll have lots of valve float and make squat for power or worst, bend a valve depending on spring pressure.
Old Feb 20, 2005 | 02:41 AM
Boostaholic's Avatar
That looks like a good cam, I really wish I knew more about F/I cam selection, I'm looking for a turbo cam right now for my 408
Old Feb 20, 2005 | 09:03 AM
wow not true. ideally i wouldnt put 918 springs with that big of a lift but it has a lot to do with the lobe's aggressiveness. i would go with crane dual springs. but it would explode and die like blue99 said lol
Old Feb 20, 2005 | 03:41 PM
JerikSS's Avatar
Any idea on hp/tq numbers w/ 7psi of boost intercooled?
Old Feb 21, 2005 | 10:04 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I ran the Crane 893's with a 230/236//595/598 cam. I would not use 918's.
