Roto-master To4b
Old Feb 22, 2005 | 11:57 AM
slow ride's Avatar
Default Roto-master To4b
I have a rotomaster TO4B with a R-11 comp wheel and a P-trim ex wheel .96 ex houseing. Can I use this on my LS1? Or would I be better off using something else? This is a daliy driver stock bottem end bolt-on car. ANY help would be appreciated.
Old Feb 22, 2005 | 01:46 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Measure the compressor wheel's inducer first. That is the best thing to do to see if its worth using. A T04B is typically a pretty small unit, and not worth using on a larger V8.
Jose
Old Feb 22, 2005 | 07:22 PM
slow ride's Avatar
Jose
Not quit sure what the inducer is. But small part of the wheel is 2.312 and the larger part of the wheel is 3.003. The inlet I.D. is 2.745. So what does all this mean?
Old Feb 22, 2005 | 10:21 PM
LS1TECH Sponsor
Basically its a 58mm turbo. Probably good for 500-550hp crank. Fine for a stock unit, but not much else.
Jose
Old Feb 22, 2005 | 11:20 PM
slow ride's Avatar
Jose
550hp crank=about 450 rear wheel right? Thats not to bad. Fine for a stock unit? Do you mean a Stock motor? Not much else. What do I need?
Old Feb 23, 2005 | 12:08 AM
LS1TECH Sponsor
Yeah for a stock motor that is fine. If your are wanting more, then I would look for something a little larger. All depends on the level of power you are looking for.
Jose
Old Feb 23, 2005 | 10:43 PM
gen 3 bu's Avatar
what about twins with the same specs
Old Feb 25, 2005 | 10:25 PM
slow ride's Avatar
Jose
How does that compair to a GT67?
Old Feb 26, 2005 | 12:46 AM
LS1TECH Sponsor
The T67 is a good bit larger and will handle around 800-825hp depending on housing, and turbine wheel trim.
Jose
Old Feb 27, 2005 | 04:55 PM
slow ride's Avatar
Jose
OK I have found a different one. Air Research. Inducer is, small part 1.295. Larger part 2.750. A/R ex .96. Is this smaller than the other one? what is it good for?
Old Feb 27, 2005 | 07:05 PM
slow ride's Avatar
Jose
How does it size up to a 60-1? The reason I ask is I was thinking that I could buy a STS kit minus turbo or make something up. let me knoe what you think.
Old Feb 28, 2005 | 06:52 PM
slow ride's Avatar
JZ 97 SS 1500 are you out there?
Old Feb 28, 2005 | 07:00 PM
LS1TECH Sponsor
Going by your measurements that is a 32mm unit. That won't blow enough air to cool the sweat off my sack... ...hehe. That is no where near the size of a GT67 and a good bit smaller then even a 60-1. If your looking to run something close to a 60mm, then a 60-1 is ok, also the master power 60 series is ok. But for best results the 67 or something in that size range will work best for that size motor.
Jose
Old Feb 28, 2005 | 08:10 PM
slow ride's Avatar
Jose
That was funny Ok I have two more.TO4B's .58 A/R ex. small 1.900,large 2.750. Would these work for a twin set up. And if not what can I sell these for? They are brand new. And how much would it cost to buy the right one.
Old Feb 28, 2005 | 08:32 PM
LS1TECH Sponsor
Yeah, those units are equivalent to a pair of 48-49mm units. They are almost the same size as a GT3552. They would work pretty decent with a tiwn setup. Should be good for almost 800-900hp depending on the covers and exhaust side and potentially more.
Jose
Old Feb 28, 2005 | 08:38 PM
slow ride's Avatar
Jose
OK Now I have something to work with. Does any one make a twin kit? and will they fit.
