Comp Cams good for Turbo
Old Feb 23, 2005 | 12:41 AM
73ChevyC10LS1's Avatar
Default Comp Cams good for Turbo
I bought this cam thinking i was going to run no2 but have since changed my mind. Please let me know if this cam would still be good.
Valve lift int:.522 exh:.529 duration at .05 intake 212exhaust 218 and lsa of 114. So far i have a main support with arp main studs cryo treated crank main and rod bearing and rods. I am running the stock crank with CAT Hbeam rods mahle pistons and rings. Afr 205 heads comp cams lifters pushrods and rocker arms. The compression ratio is about 8.7. i plan on running a t76 for this. and oh yea this is all going in a 66 chevelle that i am building as we speak. please let me know if i should change anything.
Thanks
Darin
Old Feb 23, 2005 | 03:38 PM
Anybody?
Old Feb 23, 2005 | 03:47 PM
MECHAM's Avatar
its a small cam...turbos dont need huge cam profiles
Old Feb 23, 2005 | 04:13 PM
so then its good cam for my setup?
Old Feb 23, 2005 | 09:35 PM
anyone else have any suggestions?
Old Feb 23, 2005 | 09:59 PM
WS-Sick's Avatar
I've heard of stock LS1 cams making 800+ to the wheels. That cam will work but why not sell that and get a cam that will work best for your future setup?
Old Feb 23, 2005 | 10:23 PM
SS2win's Avatar
call comp..
Old Feb 23, 2005 | 10:31 PM
whats a good turbo cam then?
Old Feb 23, 2005 | 10:50 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Power goals?
Old Feb 23, 2005 | 11:26 PM
Power goals?
about 600-700rwhp
Old Feb 24, 2005 | 10:44 AM
LS1Tech Co-Founder
The added duration will help make a little more power. The setup you describe can easily make 600-700rwhp.
Old Feb 24, 2005 | 11:00 AM
kcshaner's Avatar
http://www.cmotorsports.com/engine/l...ft-design.html
scroll to the bottom, they have 10 different turbo cams. Call them and I am sure they can help.
Old Feb 25, 2005 | 05:30 PM
Wo0111's Avatar
Looking at the first grind they have it looks similar to the comp with 6* more intake duration (than the comp). I'm curious also since I have the same cam in my car, IMO it seems like it would be a good canidate (as in it's not to big).
