OBX intercooler
Old Feb 25, 2005 | 07:52 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default OBX intercooler
Okay so Im going to order the obx tomorrow. Anyone have any neg inputs I need to know about? Im going to flip the end tank before it goes on and see how that does. Either way post up if anyone has any neg or pos. opinions.
Eric
Old Mar 1, 2005 | 01:32 PM
96silverram's Avatar
Eric
You might to to texas rear turbo's site and order from them. I think there price is $290 and the shipping should be quicker.
Old Mar 1, 2005 | 02:51 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default ....
too late its been ordered. now when it comes in im going to flip the endtank.
Old Mar 1, 2005 | 04:55 PM
Avengeance's Avatar
Flip one end tank? I actually thought about doing that to my OBX... would make it actually work a little better... efficiently use more of the cores with a crossflow from corner to corner.
Old Mar 1, 2005 | 05:03 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default obx
yep I plan to flip one endtank to see how it does cross flow top inlet to bottom outlet.
Old Mar 1, 2005 | 07:30 PM
Just tryin to help
Old Mar 1, 2005 | 08:04 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default ....
thx actually if I had known I would have got it from that shop in texas now I have to wait.
Just tryin to help
Old Mar 1, 2005 | 08:35 PM
Slowhawk's Avatar
LS1Tech Sponsor
I haven't seen it neccessary to flip an end tank.A few cars I've installed them on had excellent cooling. I car- 50 deg outside air, 14lbs of boost from Turbo threw 3 gears,highest intake temp was 71 degree's.That is only a 21degree increase which is awesome.
Old Mar 1, 2005 | 08:42 PM
HellRaiser's Avatar
I agree with Slowhawk. FMIC's have been running like this for a long time way before anyone even knew what a LS1 was. But it wouldn't hurt.
Old Mar 1, 2005 | 09:17 PM
kbracing96's Avatar
Just my opinion here, but I think you might actually cause more restriction in the intercooler by flipping one of the tanks, and I think you won't see anymore cooling affect. I understand the crossflow thinking that your using, but you're not flow water in a radiator at a low speed, you flowing air at high speed, and the flow dynamics are different. The majority of the air is going to flow strait through the cooler from the inlet cuz that's the path of least resistance. As flow increases and the air volume becomes more then the tubes can flow at that pressure then air will push up the cooler to the tubes not directly infront of the inlet.
By flipping one end like you are thinking of, the bulk of the air is still going to flow strait through the cooler and then have to make a 90 to the other end of the cooler and then a 90 out of the cooler. I think that will cause more restriction and not increase cooling efficiency like you think it will.
The only way that you could increase the efficiency is to rebuild both ends of the cooler and have the in and out in the center of the tubes so it would have tubes on both sides of the inlet to "spill over" to when the flow becomes greater then the tubes there can handle.
That's my 2 cents, but let me know what you think.
Old Mar 3, 2005 | 10:34 AM
trtturbo's Avatar
I do have a few on hand and access to more. The $290.00 is shipped!!
Old Mar 3, 2005 | 12:30 PM
Cyborg's Avatar
FYI- The average temp here has been about 30-35 degrees and my IAT has averaged 54 degrees all winter (I constantly monitor it) without flipping the end tank.
Old Mar 3, 2005 | 05:31 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default endtank
I will wait. Its easier to modify the tubes the way they are so at first I will leave the end tanks the way they are. If Im satisfied with the results then I wont mess with it. Thanks for the input guys
