turbo
Old Mar 1, 2005 | 12:46 AM
nvrstsfd23's Avatar
Default turbo
I'm interested in a turbo system from sts but I got a stock 02 ramair m6 TA, my question is can I run a turbo on the stock engine or do I need to build up the engine. If so what should I do. I want it to remain driveable on the street and highway too. I'm looking for a set of heads, headers, cam too. Any ideas would be great.
Old Mar 1, 2005 | 01:53 AM
jerrad's Avatar
I beleive the sts system works great for a stock motor as long as you dont try and force 9+ pounds of boost. If you want to build your engine up you'll need low compression pistons, and forged internals. I would look around and see what some other people are doing to their bottom end and do the same. Good luck
jerrad
Old Mar 1, 2005 | 05:45 AM
smokinHawk's Avatar
if you intercool it
Old Mar 1, 2005 | 08:32 AM
trtturbo's Avatar
6.0 heads, turbo cam, injectors.
Old Mar 1, 2005 | 01:44 PM
NYSS Guy's Avatar
See sig, those numbers are on a completely stock motor, and the car drives as if it was stock, until you get into it of course!
Old Mar 1, 2005 | 02:56 PM
HellRaiser's Avatar
Why 6.0 heads? Does it lower the comp?
Old Mar 2, 2005 | 11:49 PM
nvrstsfd23's Avatar
If I get my car to 500 hp how much more could I get from a turbo
Old Mar 3, 2005 | 12:11 AM
Z06PSI's Avatar
Yes.... I picked up mine for 300.00
Old Mar 3, 2005 | 07:48 PM
studentdriver's Avatar
As long as you don't run much over 8 lbs, all you'll need will be bigger injectors, a tune, and maybe a fuel pump.
Old Mar 3, 2005 | 08:02 PM
HellRaiser's Avatar
Where did you get them from? Do they flow the same as stock LS1's?
