9.4 compression drops to what with 6.0 heads
Cylinder Diameter (inches)
Stroke Length (inches)
Chamber in cc's ----- stock 6.0L heads are 71.03 i believ or close to that.....
Piston dome in cc's (Dome = positive,
Flat = 0, dished = negative number)
Gasket Thickness in inches (add plus or
minus amount piston is in the hole)
Kyle
Kyle
6.125 rods
6.0 L heads unmilled
20cc dished pistons
stock gasket thickness
What is my compression...?????
6.125 stroke
20cc dished pistons
-Kevin
6.125 stroke
20cc dished pistons
, but I think you ment it will have a 6.125 rod length.Go to rosspistons.com and look at the calculators, they will get you close enough,( prob around 8.9 to 1).
I don't remember the stroke exactly but I think its 3.422 or something, sorry can't help more.
later,
Dave
