Turbo Sound?
Old Mar 4, 2005 | 01:15 PM
bc56f100's Avatar
Default Turbo Sound?
I have been watching a couple threads for the answer to my question, but havnt really got a concrete answer yet. I am woundering what makes that air noise on the big boy turbo kits. We have a few people here in town with the big thumper turbo's and such (over 100mm) and when they stall it up at the line it sounds like exaust for a second then comes this really loud air noise. I am woundering is this the wastegate being open to the atmosphere? Or is it just the big turbo? Thanks in advance
Billy
Old Mar 4, 2005 | 01:22 PM
777's Avatar
777
it's the big turbo...the sound of air being sucked in at large quantities and being compressed into the intake...same basic theory as a turbine powered jet...that's why they make a similar noise...the jet being much more loud of course though...it has nothing to do with the wastegate...the reason you hear the exhaust for a little while then start to hear the noise of the turbo is because the turbo is "spooling" or increasing the rpms of the impellar...once it gets to a certain speed you can hear it
Old Mar 4, 2005 | 02:16 PM
bc56f100's Avatar
Ok thanks that what I thought. So what does the wastegate sound like when its open to the atmosphere instead of run back into the exhaust? Is it just like a bad header leak? Thanks again
Billy
Old Mar 4, 2005 | 02:22 PM
777's Avatar
777
hmm...i don't know...prolly couldn't hear it over the turbo...the blow off valve makes a noise when it vents to the atmosphere..but i'm sure you already knew that...the wastegate, if you were to hear it, probably sounds similar to air coming out of a compressor...since that is what it basically is...header leaks make a ticking noise (i know cause i have one from !egr and a crappy block off haha) i doubt it will make a noise like that
i don't actually own a turbo car btw, so someone else may be better help...i've never heard a wastegate make noise before though...just speaking from personal experience
Old Mar 4, 2005 | 02:25 PM
bc56f100's Avatar
Ok cool thanks for the help, maybe someone else knows a little about it. Thanks
Billy
Old Mar 4, 2005 | 02:50 PM
JERRY2500's Avatar
14 Second Truck Club
The waste gate will make a loud hissing noise, sounds similar to air coming out of a compressor.
Old Mar 4, 2005 | 03:09 PM
smokinHawk's Avatar
whistle tips man they go wooot wooot!
Old Mar 4, 2005 | 03:42 PM
bc56f100's Avatar
LOL I herd that!!
Thanks
Billy
Old Mar 4, 2005 | 04:37 PM
eviltwins's Avatar
An open wastegate sounds like you have a big exhaust leak, because that's literally what a wastegate is, a big controlled exhaust leak.
Old Mar 4, 2005 | 11:00 PM
bc56f100's Avatar
Cool I got a vid. a moment ago and found out that is exactly what it sounds like. I will definitly run it back into the down pipe. Thanks guys
Billy
