Pics of F3R intercooled setup
Old Mar 8, 2005 | 12:23 PM
aluminumblockCock's Avatar
MAJOR traction issues
Old Mar 8, 2005 | 12:25 PM
GTBMad's Avatar
Originally Posted by ls1290
How are planning on keeping the heads down with 20-25 psi of boost? Looks nice.
Keith
We are using the new SCE Titan copper head gaskets for LS1 motors and oringing the setup. We are also using special order ARP 1/2 inch studs. We have purposely not bored the block but left it at 4.000bore and resin filled the block to reduce the flex.
Old Mar 8, 2005 | 12:26 PM
sb427f-car's Avatar
SSU'S Vice Mod
What kinda power numbers are you hoping for? I know of one guy that runs Cecil Co. in Maryland with a 69 Camaro, BB, and an f3r setup...it sound absolutely sick. And the ETs are even sicker, it's quick, that's all I can remember.
Old Mar 8, 2005 | 12:28 PM
sb427f-car's Avatar
SSU'S Vice Mod
Resin filled the block?? You mean you don't have any h2o jackets any more? Pure drag car?
Old Mar 8, 2005 | 12:38 PM
NA$TY-TA's Avatar
Damn this setup sounds sick.... be sure to post up your results.
Kyle
Old Mar 8, 2005 | 12:42 PM
GTBMad's Avatar
You fill the block to just under the block plugs to help with flex but still allow water flow.
Power numbers should be available in a couple of weeks what it should make is around 1200/1400 rwhp just have to wait and see I might only make 800rwhp
Old Mar 8, 2005 | 01:16 PM
sb427f-car's Avatar
SSU'S Vice Mod
Kyle
Considering the F3R is about the size of a basketball, you do the math
Old Mar 8, 2005 | 01:21 PM
LSONE's Avatar
On second thought, you dont want something that powerful, so just crate up your engine and we can do a swap. i'll take yours and you take my cammed engine. i say its an even trade off, and hell, i'll even pay for shipping!
 Michael S. Palmer
Old Mar 8, 2005 | 01:31 PM
Parker TX's Avatar
F3R on a street car???or drag car, also will that air2air work fine with a blower that big. You should put down some #s with that monster.
Old Mar 8, 2005 | 01:43 PM
smokinHawk's Avatar
Air filter position is still beimg worked out not a lot of space under there.
id do some type of "J"-pipe and get the filter to the front or where it can get some cold air
on second thought who needs a filter with a F3R?
Old Mar 8, 2005 | 02:02 PM
eviltwins's Avatar
Yikes, get that air filter out of there. WAY too small, that F3R will eat it up and it is not pretty when something like that gets injested. Seriously, I have a friend who destroyed his 101mm turbonetics on his street car because it sucked in the stubby little filter he had on it. Get a screen on there ASAP.
Old Mar 8, 2005 | 02:26 PM
  #32
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice. What engine management system?
Old Mar 8, 2005 | 04:22 PM
  #33
blackz93's Avatar
i had to do a double take when i read that!
Old Mar 8, 2005 | 05:09 PM
  #34
GTBMad's Avatar
This will cause some argument but we have done the testing and have been running some 2/3 bar on stock PCM, obvoiusly we run in speed density.
In regard to the air filter it is only a dummy up and not the final setup.
This is a street car, but we will be using it for some drag work the idea at the moment is to just have some fun no seroius stuff.
If we get seroius about racing it will be in a GTO body shell
Old Mar 8, 2005 | 05:11 PM
  #35
777's Avatar
777
can you say big??
Old Mar 8, 2005 | 05:23 PM
  #36
sb427f-car's Avatar
SSU'S Vice Mod
Originally Posted by 777
can you say big??
I said it's bigger dan y0! head Like I said, bout the size of a basketball. Maybe even a small watermellon. GTBMad, you're downunder right?
  #37
NA$TY-TA's Avatar
That F3r is total over kill..... and that cog pulley will be wau to much.. way to small... I know because i abuddy of mine on here has a F2 on his car and with it it was making 30+ psi of boost and lifting the heads with the same studs you are using...... he had to DEtune it....... Way over your HP estimates..... and will filling the block how and the hell are you going to keep it cool with street driving it?????? Please tell us..... and with a stock PCM you might run into some trouble even with the 3 bar MAP esp. if you max it out....... with all the $$$ youve spent so far whats a little more???
Kyle
Old Mar 8, 2005 | 05:36 PM
  #38
mzoomora's Avatar
14 Second Truck Club
That thing is insane! If you are looking for a filter there is a listing on K&N's web site that lists all the filters by dimension. Might be worth a try, but you might not find anything that can flow the kind of air you need without collapsing.
Old Mar 8, 2005 | 05:40 PM
  #39
LS1Tech Co-Founder
Neat setup, but for 1200-1500 hp I would be using a BS3 or something. You are going to run 160 lb injectors?
Old Mar 8, 2005 | 05:42 PM
  #40
GTBMad's Avatar
We have 3 different pulley sizes, we have already had this unit working on another install 422ci with no problems.
Yes its a street car but get real it aint no daily driver.
Nasty you are a bit negative on some of this but dont knock it just yet you blokes still use MAFS over there dont you.
All I was trying to do was share what I am doing, yes we might have to go to another tuning system but we can cross that bridge latter. From prevoius experience I have learnt that when you push the boundary other issues will need addressing.
In relation to heads lifting been there had that problem hopefully we can fix that issue also.
