Pics of F3R intercooled setup
Originally Posted by Sandmann120
That is fooking AWESOME. What is the rest of the details about your setup? Plans, etc? Where did you get that bracket? Again, awesome.
This is being bolted to a 6 litre cast block resin filled/ oringed with 1/2 inch studs. Heads are the lq4/9 317 casting custom built. We had to get custom T&D due to the geometry and that we are using a solid roller cam @260 plus and 700 plus lift.
Will be running 20/25 psi any body guess how many horses
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
I believe you can just call K&N with the measurements you need for a filter and tey'll make one for you. Read that in another FI post. Props on the build. Definitly go to the bathroom before you drive.
Originally Posted by smokinHawk
very nice, just beautiful.
but im not a big fan of the air filter right above the headers.
Nice setup, will it all fit under that stock hood?
We had to move the custom radiator forward and remount. The imtercoo;er is like 5 inches thick.
SSU'S Vice Mod
Originally Posted by GTBMad
Yeah just, but there has been some mod work to the engine bay to fit the pipe work and intercooler.
The core is awsome!! It looks like a dang IC from a Dodge Diesel pickup it's that HUGE!!!!
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
