Twin roots blower setup?
Old Mar 9, 2005 | 11:51 PM
thunder550's Avatar
High on diesel fumes
Default Twin roots blower setup?
I have a couple of questions about twin-supercharger setups.
First, what is the advantage? I read somewhere that unless you run them in a series (outlet of one supercharger feeds the inlet of the second), you don't get any additional boost. Would the additional volume of air make a difference if I don't see a drop in boost at redline anyway?
Second, does anyone know if Magnacharger makes a setup like this? Someone mentioned in passing in another forum that they make a manifold that will hold two blowers, similar to the twin-supercharged engines from www.nelsonracingengines.com, but their website doesn't have anything about it. I sent their tech guys an email, but haven't gotten a response.
Thanks!
Old Mar 10, 2005 | 07:28 AM
chuntington101's Avatar
i think the main advantage of, say twin mags, is the volume you can shift per rev. the most you can move with a single whipple is 3.3ltr, but if you used 2 of the 1.6ltr (pretty small bower that would be easy to package) then you are getting 3.2, not that far off so if you went for two 2.3ltrs......also, as you can shift more air you can spin the blower slower and thus reduce inlet temps. also coz you would normaly mount the twin blowers not on top of the engine, so it is easier to incorp a intercooler, and you could run a more effective (on the road) air to air intercooler as well.
a lot of manufatures run single blowers (Jag, merc, etc) but Aston did use a twin blower set up on their old V8!
Thansk Chris.
Old Mar 10, 2005 | 02:18 PM
granitemonkey's Avatar
They have some baddass motors on that site.
Old Mar 10, 2005 | 05:53 PM
thunder550's Avatar
But to use two full-size blowers, is there an advantage?
Old Mar 10, 2005 | 11:25 PM
thunder550's Avatar
Nevermind...I just talked to someone at Magnacharger, and for a small block he said I wouldn't gain much, if anything.
Old Mar 11, 2005 | 12:45 PM
MrDude_1's Avatar
Thanks!
you have to run them parallel.. not in series...
positive displacement blowers work by moving X volume of air into a smaller space...
for example, my eaton M112 moves 112Ci of air per revolution.
of course, to shove enough air into a larger motor, you have to spin it faster.
when it spins faster, there becomes a point where its less efficent... it starts heating up the air too much and you'll start to lose power.
by running two of them, say dual M90s, instead of 90ci of air per rev, you get 180ci of air per rev.... you can then spin the slower, hopefully in the "sweet spot" and make more power.
but really, its better to run one large, efficient supercharger then two smaller ones.......
Old Mar 11, 2005 | 02:12 PM
LS1 Hybrid Magna's Avatar
Mr dude ....are you "saturn5" on third gen org????????????
is this the twin eaton ford SC mafia?????
Old Mar 11, 2005 | 02:21 PM
MelloYellow's Avatar
There was one LS1 that had them setup in Parallel. There was debate as to whether is was real or photoshop. Might have been from Australia.
Old Mar 11, 2005 | 02:39 PM
mello...you are getting things mixed up------
hope that the links below help clear the smoke......
the owner of the malibu is for real
the car is well known on third gen org!!!!!!!!!!!!!!!!!!!!
check this old thread from us on ls1.tech and com and third gen
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Tryed to gather some Eaton/Magna infos and this came up!!!!!!!!!!!!!!!!!
Funny things pop up when you press the search button and dont need a Industrie kit to make a M112 run!
4th gen guys read this:
Third Generation F-Bodies > Tech Boards > Power Adder > Eaton M112 Runs!
http://www.thirdgen.org/techbb2/show...ght=eaton+m112
4th gen LT1 Eaton website:
http://community.webshots.com/album/73249682zNpxhw/1
Eaton m112 with 1000HP?
Third Generation F-Bodies > Tech Boards > Power Adder > Twin Eaton breathing air
Magna Talk ?
LS1TECH > LS1-LS2-LS6-LS7 PERFORMANCE > Forced Induction
https://ls1tech.com/forums/forced-induction/252210-tony-johnopls-3rd-gen-magna.html
Real world compares avoided??? Magna/ATI?
LS1.Com Forum > LS1 Specific Technical Discussion > LS1 Forced
http://www.ls1.com/forums/showthread.php?t=543222
Pro Talk about magna? While the backyard is running 10th with a homemade “Magna”!
http://www.toohighpsi.com/SCTC/sctc.htm
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXX
ATTENTION if you know someone running a magnacharger hybrid pls let me know!!!!
Old Mar 11, 2005 | 03:10 PM
MrDude_1's Avatar
lol, no, im not Saturn5... but you're right, thats his car.
edit:
btw im MrDude_1 on thirdgen.org.... and everywhere else too.
Old Mar 11, 2005 | 03:18 PM
MrDude_1's Avatar
if by magnacharger, you mean eatonM112.... Rooster (or somthing like that) on Camaroz28.com had a setup like that on his LT1....
Old Mar 11, 2005 | 04:26 PM
hahahah Mr. Dude you always make me laugh!!
Those two eatons must scream like music.....
Right Mr. Dude ! magna or eaton bring it in and let me see some webside where folks have build some!!!!
Yah...sorry to hear that rooster lost some bizz due to a ripper on his patent pend. stuff...if i remember right!
So Mr. Dude this is a pic from country that produces the best car in the world:
blower big boss BENZ
for the money you spend on this sucker you could build a 3rd gen Fbody that can FLY!
does anybody know of a W 114 Mercedes Benz ...with a chevy V8 engineswap??????
Attached Thumbnails Twin roots blower setup?-benz-lader.jpg   Twin roots blower setup?-benz-lader-1.jpg
Old Mar 12, 2005 | 01:08 PM
Third Gear's Avatar
http://www.harrop.com.au/products/ro...en/engine.html
The Australians are freakin crazy (in a good way mates ). Watch the video with the eaton blower... sounds like a Cobra to me, very sweet.
Also the IR manifold looks sweet too, although you loose bottom end torque. Looks like about 262 lb/ft of torque at 2000 RPM. Sounds bad *** too
