Airpump to remove Crank case pressure under boost?
Old Mar 10, 2005 | 01:38 PM
Arkangel77's Avatar
I honestly think that the guy who built the motor gapped the rings wrong BUT a compression test would defiantly identify a serious problem! Thanks for the advise, Lata, Ark
PS - anyone have any experiance with the SSBC pump?
Old Mar 10, 2005 | 01:51 PM
Got Me SOM's Avatar
There's your answer right there. I'd make the guy redo the engine .
Old Mar 10, 2005 | 04:06 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Idle speculation on the part of the witness your honor.
I have triple the crankcase pressure of stock. At half you still need to do something.
Old Mar 10, 2005 | 04:56 PM
strokedls1's Avatar
I was actually thinking about plugging all the pcv and passanger valve covers, and connecting the stock air pump in reverse phase onto the driver side rear valve cover spot with an inline filter.
Old Mar 10, 2005 | 05:16 PM
LS1Tech Co-Founder
I gave my air pump to Intmd8 a few years ago, and I recall him saying it did not pull enuff.
At a mininum folks have to run breathers if you are making a lot of power.
Old Mar 10, 2005 | 05:43 PM
stevieturbo's Avatar
Are the extract systems that attach to the exhaust via a pcv valve any good ??
How good or free flowing does the exhaust system need to be for them to work, or does it really need to be an open exhuast ?
Old Mar 10, 2005 | 06:31 PM
Arkangel77's Avatar
I Just figured Breathers would bleed oil onto the motor BUT Maybe not? WE will see? I was just hoping that Vac pump in addition to the Exhaust extract systems would be a viable option?
Old Mar 10, 2005 | 06:33 PM
JMBLOWNWS6's Avatar
Originally Posted by ls1290
$80 solution and works the best
Keith
I took Pro Stock John's advice
Old Mar 10, 2005 | 06:48 PM
Arkangel77's Avatar
DOes it leak oil down your motor? I guess I would need some different Valve covers that would allow me to put a breather onthe Drivers side?
Old Mar 11, 2005 | 05:45 AM
smokinHawk's Avatar
just disconect your PVC lines from the valve cover and use those ports as breather lines (unless you have an lt1 and im not sure about it then)
BTW: when i was having crankcase pressure and my rings were worn i had a leak down test done and everything checked out ok, so doing a leak down may not show your problem that the rings are worn.
Old Mar 11, 2005 | 08:52 AM
Arkangel77's Avatar
I have a LT1 and I only have a Hole in One Valve cover BUT I can fix that fast!
Old Mar 11, 2005 | 08:57 AM
  #32
Camaro_Zach's Avatar
haha yes! i love that attitude!
Old Mar 11, 2005 | 10:11 AM
  #33
Wet 1's Avatar
Does anyone have a picture or two of a breather & catch can setup?
Is there any odor problems with this setup?
Old Mar 11, 2005 | 11:07 AM
  #34
Ryan K's Avatar
Pathological Modifier
I have a question, where does your system go into the exhaust? If you have an STS system, it has to go after the turbo... If its before the Turbo, it will never relieve.
Ryan
Old Mar 11, 2005 | 12:25 PM
  #35
mzoomora's Avatar
14 Second Truck Club
Another thing you have to consider is that AIR pumps are designed to push air, not pull. A good one to use would be a vacuum pump like many HT4100 Cadillacs(and many other cars) had. I know it sounds weird, but it would be similar to a electric in-tank fuel pump, they dont pull fuel well because they are designed to push it.
Old Mar 14, 2005 | 12:13 PM
  #36
BOONE's Avatar
I just ran my passenger side cover to a catch can, then to a clear gas filter,( as a second mini catch ) and took out the pvc altogether. Then to the inlet hat and i am yet to see any oil in the catch can ever, the filter gets dark then i change it and thats it. Works for me, although not optimal i suppose. There is just this oily film on all of it and it seems to accumulate in the filter media the most. In 3 or 4 thousand hard miles it still has the same filter in it but it needs changed before spring.
