Bov
Old Mar 10, 2005 | 09:52 AM
Juiced's Avatar
Default Bov
Hey Is a 50mm BOV flow enough air to work with 16lbs of boost?
Old Mar 10, 2005 | 09:53 AM
mongse's Avatar
I ruin the end of films...
Depending on the amount of air being moved, it should be. I've got a single TiAL 50mm on my twin setup.
Old Mar 10, 2005 | 01:13 PM
Fullthrottledan1
Guest
Posts: n/a
same here, single 50mm tial on twins. works great
Old Mar 10, 2005 | 01:31 PM
Boostaholic's Avatar
I am running a single 50 with my twins, may have to add another but I think it should releieve enough pressure to stop bad things from happening, remember that blowoff valves are not required in all cases, they just prevent wear on the turbo.
Old Mar 10, 2005 | 02:49 PM
smokinHawk's Avatar
i think ronnie duke was running a single tail 50mm BOV on his beast
Old Mar 10, 2005 | 02:55 PM
I think its less important for superchargers to relieve pressure fast than turbos, the turbos can see instant pressure and potentially stop abruptly where the supercharger will keep forcing some air even out a restricted bov
Old Mar 10, 2005 | 06:32 PM
BlwnTA's Avatar
7 Second Club
Yep, but don't forget the strain on the system including belts and pulleys. Of course, only on high boost applications
