Twins on a 2004 Z06?
Old Mar 14, 2005 | 08:00 PM
Saybye's Avatar
Default Twins on a 2004 Z06?
2004 LS6 Corvette.......Bone stock and very few miles. I have added, upgraded and tastefully pimped out the interior. Instead of paying another 30K for a 2005 Z06.....I want more power in what I have.
Not really a daily driver but I do go out in it on sunny days. 8.08 et in 1/8 mile is my best time. Power is infectious!
How about twins on a LS6? Any info and your experience would help.
Thanks
Chris
Old Mar 14, 2005 | 08:09 PM
cwbpartsguy's Avatar
sts turbo is currently prototyping a c5-6 turbo kit
2MuchRiceMakesMeSick's Avatar
Z06 has a little bit higher compression then a regular vette. They make several twin turbo kits for our cars. I know of one kit (not a sponsor) that made 670 with 9.5 psi on a STOCK Z06 Of course you cant expect your engine to last long under that kind of force.
Old Mar 14, 2005 | 08:19 PM
Got Me SOM's Avatar
twins should come stock on a z06. definitely do it!
Old Mar 14, 2005 | 08:29 PM
Saybye's Avatar
I'm definitely going to do it. Love drag racing too much not to do it and I have a bit of experience with Twin turbo's on a limited street car producing 2200 hp @25lb's of a possible 30 lb's boost; but, the bottom end was built for the abuse.
Z06's should withstand 5, 6, or 7 lb's with an excellent tune. The system or finding the kit is the challenge. I just left the STS site and noticed one may be in production.
How about Banks engineering? Has anyone heard of a kit in production?
Old Mar 14, 2005 | 08:54 PM
6 psi is around 550 rwhp. Its a bit much for stock internals. http://www.turbochargedpower.com/Corvette.htm
Old Mar 14, 2005 | 09:19 PM
69firebird's Avatar
turbo tech makes a really nice kit, it has cast manifolds, really nice
try them out
Old Mar 14, 2005 | 11:30 PM
NumberOneSled's Avatar
PTK makes a twin turbo kit for the vette--------------------->
Old Mar 14, 2005 | 11:38 PM
nick y's Avatar
check out corvette forum search ptk tread i will run ptk. youll need to spend over 20k if your going all out maybe 24k
Old Mar 15, 2005 | 05:38 AM
smokinHawk's Avatar
turbotech and ptk would be my top choices
Old Mar 15, 2005 | 06:49 AM
Wet 1's Avatar
There are several kits out. TTi has a new stage "X" kit that's very impressive.
Check here for more TT kit info:
http://forums.corvetteforum.com/forumdisplay.php?f=86
Old Mar 15, 2005 | 06:50 AM
Wet 1's Avatar
BTW, you should be able to run 8-9 lbs with a good tune on a Z06.
Old Mar 15, 2005 | 11:15 PM
solobaric's Avatar
Don't know what you want to spend, but one word comes to mind, Lingenfelter.
Old Mar 16, 2005 | 01:22 AM
BIGBOS's Avatar
You can run 5-7 PSI safely with enough fuel/injector, and a good tune, have the AFR at 11:1 on the sheet and reduce timing....pump gas, should make at least 500 rwhp on a stock Zo6....if not more
Old Mar 17, 2005 | 09:59 PM
LuvmyC5's Avatar
IF you want bling bling, then the PTK is worth a look. It has the over the top headers, and is suppose to put out decent power, but haven't seen any dyno sheets yet. They make some killer Mustang turbo systems though.
If you want a tested Twin setup, that is stealthy, then I'd definitely look at the TTi Stage X kit. There are stock cube C5's that are putting out 700+rwhp (not Z06's). This is my favorite (maybe until the Phamspeed one comes out, but we'll see).
Good Luck!
Old Mar 22, 2005 | 08:07 AM
Ed Potter @ LPE's Avatar
Closed ex-Sponsor Account
If your interested in the best Corvette twin Turbo kit on the market, ck out this link: http://www.lingenfelter.com/pack_cor_c5_550.htm
Our stage I package will make over 500RWHP on your ZO6 at 5-6 PSI, and drive as smooth as the stock car! It's also tuned to perfection, and covered by our 2yr/24K warranty. The package is currently on sale for $18,500.00
Let me know if I can answer any questions for you,
Ed
